Upload randomly fails
gutauckis
When uploading a large amount of files, it randomly fails. Once in a while it even completes successfully.
Using .NET, the version of the WinSCPNet is 1.3.6.7136.
Im using the following code:
With mySessionOptions
      .Protocol = Protocol.Ftp
      .HostName = "vaultcracker2"
      .UserName = "XXXXX"
      .Password = "XXXXXXXXX"
   End With
   Using mySession As Session = New Session
      transferOptions.TransferMode = TransferMode.Automatic
      transferOptions.SpeedLimit = 2500
      transferOptions.ResumeSupport.State = TransferResumeSupportState.Smart
      ' Connect
      mySession.Open(mySessionOptions)
      'Create Remote folder
      If (mySession.FileExists(szRemoteFolder) = False) Then
         mySession.CreateDirectory(szRemoteFolder)
      End If
      ' Upload files
      transferResult = mySession.PutFiles(szSavedFolder, szRemoteFolder, False, transferOptions)
      ' Throw on any error
      transferResult.Check()
      For Each transfer In transferResult.Transfers
         Console.WriteLine("Upload of {0} succeeded", transfer.FileName)
      Next
   End Using
The message I get back is: Error transferring file 'c:\a\xxxx.txt', Copying files to remote side failed.
When I look at the server log all I see is: FAILED UPLOAD
No other information is given as to WHY it failed.
Re: Upload randomly fails
Please attach a full session log file showing the problem.
Log attached. While you are looking at it I have found that I have another issue;
I am trying to set the folder permissions on upload and its not working.
Here is the code
Dim myFilePermissions As New FilePermissions
                myFilePermissions.Octal = "755"
                transferOptions.FilePermissions = myFilePermissions
Interestingly enough when I FTP with the same user with Filezilla I am able to change folder permissions so I don't think its a umask issue as mentioned in another post.
  • log.txt (134.18 KB, Private file)
Description: Session Log
