www-data login
hell0world
www-data login
First post here.
To begin with, congratz on the amazing software. I'm hosting a few websites here and there and WinSCP is in my top-list when it comes to managing files remotely.
Now I have a simple (I think) question for you guys :
I'd like to know if there is any way to either login as 'www-data' when using SFTP without having to modify 'www-data' user's settings or if there's a way to run a script at logon or when adding/copying files trough WinSCP to automagically set the owner/group to 'www-data'. That'd save time when editing website files.
Many thanks,
Pierre-Luc
Re: www-data login
Can you elaborate on "login as 'www-data' when using SFTP without having to modify 'www-data' user's settings"?
There's possibility to execute commands post-login with the FTP protocol only.
No post-transfer commands.
Thanks for the reply.
That answer my question. A post-transfer script when using SFTP would have indeed been what I was looking for.
I'll handle 'www-data''s permissions manually.
