[SOLVED] - Ignore password promt when useing Private/Publik Keys?
Muffinz
Sweden
I'm trying to get my Powershell script to login and upload som files on a FTP server. It works great with Putty/psftp.exe.
The connection is SFTP with a username, a Key-file that has a passphrase on it and no password.
But I can't get it to work with WinSCP .Net or the Powershell module.
This gets me a login promt at $session:
$sshKeyFinger = "ssh-rsa 2048 xx:cc:vv:bb"
$sshKeyPath = "\\UNC\Path\to\Key.ppk"
$sshpw =  ConvertTo-SecureString "Password" -AsPlainText -Force
$session = New-WinSCPSession -HostName Username@host.com -SshPrivateKeyPath $sshKeyPath  -SshPrivateKeySecurePassphrase $sshpw -SshHostKeyFingerprint $sshKeyFinger
Send-WinSCPItem -Path \\local\unc\path\* -WinSCPSession $session -Destination /transfer
Remove-WinSCPSession -WinSCPSession $session
and with this:
# Load WinSCP .NET assembly
Add-Type -Path "WinSCPnet.dll"
# Set up session options
    HostName = "Host"
    UserName = "UserName"
    Password = "SSHKey_Passphrase"
    SshHostKeyFingerprint = "ssh-rsa 2048 xx:cc:vv:bb"
    SshPrivateKeyPath = "\\UNC\Path\to\Key.ppk"
$sessionOptions.AddRawSettings("AuthKI", "0")
try
    # Connect
    # Your code
    $transferOptions.TransferMode = [WinSCP.TransferMode]::Binary
    $transferResult = $session.PutFiles("\\Local\UNC\Path\*", "/transfer", $False, $transferOptions)
    # Throw on any error
    $transferResult.Check()
        # Print results
        foreach ($transfer in $transferResult.Transfers)
            Write-Host ("Upload of {0} succeeded" -f $transfer.FileName)
    finally
        # Disconnect, clean up
        $session.Dispose()
I get this error message:
Exception calling "Open" with "1" argument(s): "Connection has been unexpectedly closed. Server sent command exit status 0.
Using username "Username".
Authenticating with public key "rsa-key-".
Authentication failed."
At line:20 char:5
+     $session.Open($sessionOptions)
    + CategoryInfo          : NotSpecified: (:) [], MethodInvocationException
    + FullyQualifiedErrorId : SessionRemoteException
Any idea?
Re: Ignore password promt when useing Private/Publik Keys?
I "solved" it with this code :)
Add-Type -Path "\\srv\Script\FTP\WinSCP-5.9.3-Automation\WinSCPnet.dll"
    HostName = "HostName"
    SshHostKeyFingerprint = "ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
    SshPrivateKeyPath = "\srv\Script\FTP\psftp\Key.ppk"
$session.SessionLogPath = "C:\Temp\Log\Uploaded.log"
$sessionOptions.SshPrivateKeyPassphrase = "Password"
try
    # Connect
    # Your code
    $localPath = "C:\Temp\test\*"
    $remotePath = "/SomeRemoteFolder"
    # Upload files, collect results
    $transferResult = $session.PutFiles($localPath, $remotePath)
    $transfer.FileName)
finally
$session.Dispose()
catch [Exception]
Write-Host $_.Exception.Message
exit 1
But now I get another error code instead:
Error code: 4
Error message from server: Failure
Common reasons for the Error code 4 are:
Renaming a file to a name of already existing file.
Creating a directory that already exists.
Moving a remote file to a different filesystem (HDD).
Uploading a file to a full filesystem (HDD).
Exceeding a user disk quota.
Asking user:
Cannot overwrite remote file '/SomeRemoteFolder'.$$
  • Uploaded.log (12.62 KB, Private file)
Description: The Log file
