Script has stopped working
Gallusnation
I've been using a generic 'put' script with WinSCP for years and not had any issues. The below script has stopped working, however, and I cannot find the reason why. The scheduled task outcome appears to state that a command is incorrect:
# Automatically answer all prompts negatively not to stall
# the script on errors
option batch on
# Connect to the session in WinSCP (defines folder locations)
open HousingPartners
# Force binary mode transfer
option transfer binary
# Upload file with the mask to the remote directory
put "HHExtract*.xlsx"
# Exit WinSCP
This script was previously working fine with this scheduled task, but appears to have stopped working some time in the last 4 weeks. I had a similar task that also stopped working around the same time, however this appeared to be an issue with permissions on a suppliers SFTP server which has now been resolved. I've also double checked that the session name is correct.
Has one of the commands been deprecated or something?
Re: Script has stopped working
The script uses some obsoleted commands (like option transfer), but all of them are still working in the latest version of WinSCP.
It turns out it was probably related to the Windows Scheduled task. I completely removed the task and set it up again and it is now working (no changes have been made to the script or to the commands used as parameters).
It may also have been an issue with permissions for the service account used to schedule the task. The script was not to blame however.
