Check file existence
thomasFrh
Hello all,
I try to find out how I can check whether a file exists. If the file not exists I want to send an email (-> backup script):
winscp.com /log=log.log /ini=nul /command ^ "option batch abort" ^ "open ftp://test:test@localhost/" ^ "option failonnomatch on" ^ "ls test.sql" ^ "exit"
if %ERRORLEVEL% neq 0 goto error
:error
echo No file found -> email
pause
exit 1
echo test
My question is how I have to change the script, because of course "ls" does not run... Unfortunately it is not possible to download the file, because the files are very big..
Maybe someone can help me!
Thomas
ansonee1
Check File Existence With Winscp.exe
I have found a ton of posts that instruct you how to check for the existence of a file, but every example I have found is for using WinSCP.com - I have yet to find an example that demonstrates how to use WinSCP.exe and how to check for a file with a mask.
Is there someplace I can find an example of this?
Re: Check File Existence With Winscp.exe
Your duplicate post:
https://winscp.net/forum/viewtopic.php?t=26959
