Can COM work with MFC
Can the WinSCP COM library be used with Visual studio 6.0 and 2013 (MFC dialog based application) for implementing SFTP protocol? It has to work on both Windows XP as well as Windows 7. Any suggestions?
readme_automation.txt. That gives me a .tlb file which I can use in the Visual Studio directory. But how do you use COM component in a MFC project?? I tried importing WinSCPnet.dll in the project, but it's showing the file is binary and cannot be read. Please help.
SessionOptions, Session, etc how can we invoke it from MFC application?
Open command when IDispatch is used. Only if we know the exact syntax can we invoke the method using Invoke in IDispatch, isn't it?
