Drag & Drop confirmations between local and remove
PaulGavrilenko
It is very useful to set up Drag & Drop to prevent accidental directory-to-directory moving within the remote panel.
However, once Drag & Drop conformation enabled it also requires confirming on moving files from local panel to remote, this is useless because such moving cannot be accidental.
I found no way to switch it off, so could a new setting be added as a checkbox "Drag & Drop (Local-Remote)" / "Drag & Drop (Remote only)" to Options > preferences > Confirmations?
Thanks.
