Directory Transfer: Multiple file mask
Andres
Hi guys. Thanks for this awesome library :) its helping a lot.
Im working with VS2015 c# and I have following code.
// Upload files
TransferOptions transferOptions = new TransferOptions();
transferOptions.TransferMode = tmde;
transferOptions.FileMask = jsonConfig.files_mask; // that will contain "*.jpg;|*/";
 SynchronizationResult syncResult = session.SynchronizeDirectories(SynchronizationMode.Remote,
        jsonConfig.local_path,
        jsonConfig.remote_path,
        false,
        false,
        SynchronizationCriteria.None,
        transferOptions);
But sadly it works only with the last or only one file mask.
Is there any way to add more than one?
Thanks in advance.
Andres
Thanks Martin, now I get it.
If anyone is interested, This make the trick to filter by file type and exclude sub folders:
*.jpg |  */
For instance:
transferOptions.FileMask = jsonConfig.files_mask + " | */";
[/code]
Jovy
How to transfer multiple file types
I've succeeded to transfer one file type but how do I code it in script and batch file? For instance I need to transfer both csv and txt file? How should I append it.
Re: How to transfer multiple file types
It would help, if you show us your current code.
Until you do, I can only point you to the documentation:
https://winscp.net/eng/docs/file_mask#combining
