Script does not accept parameters from Batch launch
Unable to connect to host "C" when trying to launch WinSCP.com script from a batch file with variables as parameters.
If I run the command manually in the cmd window it works correctly. From the WinSCP log it appears the host name is being changed to C even though, the command output appears correct.
Scripts were sanitized to remove private info
############### Batch to launch WinSCP script ###############
@echo off
REM Set Global Variables
set scpdir= "C:\Program Files (x86)\WinSCP"
set scpexe=winscp.com
set scpscript= "C:\Users\username\Scripts\scp-saconvert.txt"
set keyfile= "C:\Users\username\Scripts\win_key.ppk"
REM Get user input for SA location and server name
set /p safolder= "Input local sa folder location:"
set /p servername="Input linux server name or IP:"
set /p userid="Input User ID:"
REM launch WinSCP script to convert Files
echo Executing WinSCP to %servername%:22 with script: %scpscript%
%scpdir%\%scpexe% /script=%scpscript% /log=c:\temp\scp_debug.log /parameter %userid%@%servername%:22 // %keyfile% // %safolder%
############### WinSCP script ###############
#Set global options
#Establish connection with server
open scp://%1% -privatekey=%2% -hostkey=*
#Change directory to sa locations on local and remote servers
lcd %3%
cd /home/dt
#Upload sa files to sar dir on destination
put ./sa?? sar/
#execute the saconvert script
call ./saconvert.sh
#download sar_all file
get sar/sar_all
############### WinSCP log output ###############
. 2017-01-06 10:56:03.060 --------------------------------------------------------------------------
. 2017-01-06 10:56:03.060 WinSCP Version 5.9.2 (Build 6958) (OS 6.3.9600 - Windows 8.1 Enterprise)
. 2017-01-06 10:56:03.060 Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\
. 2017-01-06 10:56:03.060 Log level: Normal
. 2017-01-06 10:56:03.060 Local account: DOMAIN\username
. 2017-01-06 10:56:03.060 Working directory: c:\Program Files (x86)\WinSCP
. 2017-01-06 10:56:03.060 Process ID: 16488
. 2017-01-06 10:56:03.060 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe" /console=592 /consoleinstance=_9220_403 "/script=" "C:\Users\username\Scripts\scp-saconvert.txt" "/log=c:\temp\scp_debug.log" "/parameter" "user@172.27.9.10:22" "//" "C:\Users\username\Scripts\win_key.ppk" "//" "C:\Users\username\Desktop\DTInfo-scldf-server1-2017.01.04-15.44.11\var\log\sa"
. 2017-01-06 10:56:03.060 Time zone: Current: GMT-5, Standard: GMT-5 (Eastern Standard Time), DST: GMT-4 (Eastern Daylight Time), DST Start: 3/12/2017, DST End: 11/5/2017
. 2017-01-06 10:56:03.060 Login time: Friday, January 6, 2017 10:56:03 AM
. 2017-01-06 10:56:03.060 Script: Retrospectively logging previous script records:
< 2017-01-06 10:56:03.061 Script: Opening session using command-line parameter in scripting is deprecated. Use 'open' command instead.
. 2017-01-06 10:56:03.061 --------------------------------------------------------------------------
. 2017-01-06 10:56:03.061 Session name: C (Ad-Hoc site)
. 2017-01-06 10:56:03.061 Host name: C (Port: -1)
. 2017-01-06 10:56:03.061 User name: (Password: No, Key file: No)
. 2017-01-06 10:56:03.061 Tunnel: No
. 2017-01-06 10:56:03.061 Transfer Protocol: SFTP (SCP)
. 2017-01-06 10:56:03.061 Ping type: Off, Ping interval: 30 sec; Timeout: 15 sec
. 2017-01-06 10:56:03.061 Disable Nagle: No
. 2017-01-06 10:56:03.061 Proxy: None
. 2017-01-06 10:56:03.061 Send buffer: 262144
. 2017-01-06 10:56:03.061 SSH protocol version: 2; Compression: No
. 2017-01-06 10:56:03.061 Bypass authentication: No
. 2017-01-06 10:56:03.061 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2017-01-06 10:56:03.061 Ciphers: aes,chacha20,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2017-01-06 10:56:03.061 KEX: ecdh,dh-gex-sha1,dh-group14-sha1,rsa,WARN,dh-group1-sha1
. 2017-01-06 10:56:03.061 SSH Bugs: Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto
. 2017-01-06 10:56:03.061 Simple channel: Yes
. 2017-01-06 10:56:03.061 Return code variable: Autodetect; Lookup user groups: Auto
. 2017-01-06 10:56:03.061 Shell: default
. 2017-01-06 10:56:03.061 EOL: LF, UTF: Auto
. 2017-01-06 10:56:03.061 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes; Follow directory symlinks: No
. 2017-01-06 10:56:03.061 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2017-01-06 10:56:03.061 SFTP Bugs: Auto,Auto
. 2017-01-06 10:56:03.061 SFTP Server: default
. 2017-01-06 10:56:03.061 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2017-01-06 10:56:03.061 Cache directory changes: Yes, Permanent: Yes
. 2017-01-06 10:56:03.061 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2017-01-06 10:56:03.061 DST mode: Unix
. 2017-01-06 10:56:03.061 Looking up host "C" for SSH connection
Re: Script does not accept parameters from Batch launch
The problem is the space after the = in this line
fsantaana
Thanks, This corrected the issue.
Forum can be closed.
