VBA Reference clarification
Mick
Sydney
I am a new user of WINSCP with automation. I have installed and "successfully" registered the dll following the commands on the website https://winscp.net/eng/docs/library_install#registering. However when I attempt to add the reference to "WinSCP console interface .NET wrapper " the only interface I see is "WinSCP scripting interface .NET wrapper".
Is this the correct interface to use ?
If not then does that imply that it has not registered correctly ?
I have tried writing a very simple routine to instantiate the Session as per below:
Public Sub myUpload()
Dim mySession As New Session
On Error Resume Next
If Err.Number <> 0 Then
MsgBox "Error: " & Err.Description
' Clear the error
Err.Clear
End If
' Setup session options
Dim mySessionOptions As New SessionOptions
With mySessionOptions
'.Protocol = Protocol_Sftp
'.HostName = "example.com"
'.UserName = "user"
'.Password = "mypassword"
'.SshHostKeyFingerprint = "ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
End With
End Sub
This causes an Automation Error, HelpConext 1000440, and Error.Number -2146232576.
I have tried googling these but have not found any solution yet so I ammgoing to uninstall WinSCP and start again.
Please advise.
Many Thanks
Mick
Re: VBA Reference clarification
That's correct.
I've updated the documentation for the new description:
https://winscp.net/eng/docs/library_vb
What line causes this?
Do you really have the "xx:xx.." in the code or did you update it to the actual host key fingerprint?
No if you look closely all of the Statements within the "With" block have been commented out.
The code fails on the "With mySessionOptions" line, if you look at this variable in the "Watch" window thn you get the following message as the value "mySession : <Object variable or With block variable not set>".
It seems not to have nstantiated an instance of this object successfully.
As a workaround I am looking at using the scripting functionality to be fired off from Excel but not an ideal solution (and not really my strength)
Thanks fro your prompt response.
Mick
