Rename local directory files
fernanda.linsr
Hi!
I'm trying to run the script bellow and I need to rename the file from .temp to .txt after the download.
Can someone assist me?
cd /00_fidelity/00_recebimento/04_enriquecimento_kba/Bradesco
lcd C:\Users\HP\Desktop
mv *.txt *.temp
mget *.temp
rm *.temp
mv C:\Users\HP\Desktop\*.temp C:\Users\HP\Desktop\*.txt <- this doesn't work
Reply with quote E-mail
Re: Rename local directory files
The mv command works with remote files only:
https://winscp.net/eng/docs/scriptcommand_mv
One solution is to directly download the files to the desired extension:
get *.temp *.txt
Or you can rename them in a wrapper batch file using the ren command, after WinSCP script finishes.
