Files downloaded with invalid timestamps (1899/2038)
lastmohican
I'm using WinSCP.com to synchronize a local folder to a remote dir.
When I download files, the file timestamps are empty and the File "Modified" timestamp is "Dec 30, 1899 12:00:00AM".
Sometimes, the file timestamps are present, but they're in the future - like "1/18/2038 9:14PM".
This seems similar to the signed/unsigned SFTPv3-OpenSSH file timestamp error, but I'm receiving this even on the latest version(ver5.9.3) (both GUI and cmdline-scripted). (The remote site seems to use SFTP v3).
My synch cmd is like this -
synchronize local <local> <remote> -criteria=size
I need to preserve file timestamp from the remote server. I tried using "-preservetimestamp" flag but the behavior did not change.
What can I change so as to preserve the remote timestamp correctly in the downloaded file?
I've attached a compressed log file (at loglevel = 2).
Thanks in advance for all the help.
  • sftp_log.zip (2.4 MB, Private file)
Description: Compressed Log File
Re: Files downloaded with invalid timestamps (1899/2038)
It's a known problem with the server you are using:
https://winscp.net/tracker/1496
lastmohican
Thanks much for your response and the dev version!
I was able to use it successfully to download files with valid timestamps from the server.
