Issue with Script execution and upload of a file to FTP site
Gaffer007
Hi
We are running a script below to upload a CSV file from a root directory to an FTP site, the root has a new child folder created each day ( folder name is date stamp ) and the CSV name is date stamp in the child folder. When we run the below script i can see the variable populated with the latest CSV file, but the upload to FTP side of the script does not upload the file and we dont get an error, it just doesn't upload. I can manually upload using Winscp so it isnt F/W, permissions etc, can you help please?? our script is below, Thanks in Advance.
try
# Load WinSCP .NET assembly
#Add-Type -Path "WinSCPnet.dll"
Add-Type -Path "e:\Program Files\WinSCP\WinSCPnet.dll"
# Setup session options
Protocol = [WinSCP.Protocol]::ftp
HostName = "ftp.********.com"
PortNumber = 21
UserName = "********"
Password = "*********"
try
# Connect
$localPath = "F:\upload\filestoupload\"
$remotePath = "/in/"
# Select the most recent file.
# The !$_.PsIsContainer test excludes subdirectories.
# With PowerShell 3.0, you can replace this with -File switch of Get-ChildItem.
$latest =
Get-ChildItem -Path $localPath -recurse -Filter *.csv |
Where-Object {!$_.PsIsContainer} |
Sort-Object LastWriteTime -Descending |
Select-Object -First 1
# Any file at all?
if ($latest -eq $Null)
Write-Host "No file found"
exit 1
# Upload the selected file
$session.PutFiles($session.EscapeFileMask($localPath + $latest.Name), $remotePath).Check()
finally
# Disconnect, clean up
$session.Dispose()
exit 0
catch [Exception]
Write-Host ("Error: {0}" -f $_.Exception.Message)
exit 1
# exit
# Execute the script using a command like:
# "C:\Program Files\WinSCP\WinSCP.exe" /log="C:\writable\path\to\log\WinSCP.log" /ini=nul /script="C:\path\to\script\script.txt"
Re: Issue with Script execution and upload of a file to FTP site
Gaffer007
Session Syntax
Hi
Sorry with my limited scripting knowledge im struggling to output a session log file. I have checked the syntax of the command but cant see how to get it to produce a Log output when im adding in my script.
Can you help with adding the command / syntax to enable a log to be outputted?
Thanks in Advance.
Andy
Gaffer007
WinSCP session log
Hi
I managed to work out the error of my ways generating the log file. I have attached the log file.
Hope you can help
Regards
I cannot see how you cannot get any error. The script clearly fails.
WinSCP gets path F:\Symphony\iExchange\Repository\NLPG Hub\4205_20170124_01.csv (what I do not see how it corresponds to your code, which uses F:\upload\filestoupload\). And WinSCP fails to find that file. Is the path correct?
