SOLVED - Check if any file exist and return a value - Powershell
Muffinz
Sweden
How can I check if any file exist on a remote FTP-server with powershell and so the return value is False or True?
I need that value since I use Invoke-Command in an other script to call for this script and if it isn't possible I can change the script a bit so it write to a logfile and I'll have another script checking that log file.
See the "# Check File" line
This returns the value False even if there is a file on the remote location:
    # Connect
    # Remote Path
    $remotePath = "/transfer/ut/*"
    # Check File
    $Exsist = $session.FileExists($remotePath)
    # Disconnect, clean up
    $session.Dispose()
And this return me with the filename/filenames looking like this:
Files
{.., file.txt, .}
or
Files
{.., ., file.txt}
or
Files
    # Connect
    # Remote Path
    $remotePath = "/transfer/ut/"
    # Check File
    $Exsist = $session.ListDirectory($remotePath)
    $session.Dispose()
Thank you!
savoym
Re: Check if any file exist and return a value - Powershell
    # Connect
    # Remote Path
    # Check File
    $session.Dispose()
Files
{.., file.txt, .}
or
Files
{.., ., file.txt}
or
Files
    # Connect
    # Remote Path
    # Check File
    $session.Dispose()
Thank you!
You might try something like this:
if ($session.FileExists($remoteFile1)) {
Write-Output true |
Out-File -Append "C:\testTrue.txt"
} else {
Write-Output false |
Out-File -Append "C:\testFalse.txt"
Muffinz
Sweden
Write-Output true |
} else {
Thank you for the reply :)
The problem is when I use ".FileExists" I seems to be needed to specify a filename and I can't do that since all the files have different filenames.
Please correct me if I'm wrong or if I misunderstood something.
savoym
Write-Output true |
} else {
Sorry, I misunderstood where I thought you only needed to check if the value was true or false after you checked if a file existed. You may not need to use the write-out to a file but just some code logic for whatever needs to happen based on the outcome.
Something like [Linq.Enumerable]::Any($session.EnumerateRemoteFiles("/transfer/ut", $Null, [WinSCP.EnumerationOptions]::None))
Muffinz
Sweden
Ah, thank you :)
I used this solution for now
$Contents = $session.EnumerateRemoteFiles($remotePath, "*.*",[WinSCP.EnumerationOptions]::AllDirectories)
$Contents | select Name | Out-File
