Too many parameters for option option
Franzi
Im currently scripting a backupscript in Powershell. Unfortunately I get the error "Too many parameters for option option". Going through the forum it often was an outdated WinSCP-version or simple misspelling or wrong characters. I can't see any of that in my case though, maybe you can see?
Here's my script:
$BackupSource= "D:\Data\stuffandthings\"
$FTPserver   = "123.456.789.012"
$FTPport     = "21"
$FTPuser     = "Username"
$FTPpassFile = "credentials.txt"
$FTPpass     = [System.Runtime.InteropServices.marshal]::PtrToStringAuto([System.Runtime.InteropServices.marshal]::SecureStringToBSTR((Get-Content $File | ConvertTo-SecureString)))
$FTPcert     = "12:12:12:12:aa:aa:aa:aa:bb:bb:bb:bb:22:22:22:33:33:33:22:11"
$FTPurl      = "ftps://"+$FTPuser+":"+$FTPpass+"@"+$FTPserver+":"+$FTPport
$WinSCP  = "WinSCP.com" #path to WinSCP.com
$WinSCParg = @"
open "$FTPurl" -explicit -certificate="$FTPcert"
option batch abort
synchronize remote "$BackupSource" "/" -delete -resumesupport=on -preservetime -criteria=either
close
"@ #> "script.txt"
& $WinSCP -command $WinSCParg >> $LogFileCurrent
#& $WinSCP -script="script.txt" >> $LogFileCurrent
#del "script.txt"
as you can see in the end of the script I experimented with using a scriptfile, which once uncommented works just fine, like this:
$WinSCParg = @"
option batch abort
close
"@ > "script.txt"
del "script.txt"
unfortunately if I write my password into this scriptfile in plaintext all my effort of scripting this leads to a security issue, which I don't want.
Does anybody see my error?
Franzi
a little Update:
I found out, that writing the script-string into a file and instantly re-reading it into another string and deleting the file again solves the problem. So WinSCP doesn't like something about the first string. Does anybody have an idea why it won't accept the string?
Re: Too many parameters for option option
If you want to provide commands on command-line, you have to quote individual commands and pass them as a single line. Like
$WinSCParg = @""open ""$FTPurl"" -explicit -certificate=""$FTPcert""" "option batch abort" "option confirm off" ..."@
(not tested)
See https://winscp.net/eng/docs/commandline#scripting
Your finding from your second post does not make any sense.
Anyway, you better use WinSCP .NET assembly:
https://winscp.net/eng/docs/library_powershell
