Not working with Win32-OpenSSH: Error skipping startup message.
Just followed this guide and can't login with WinSCP.
https://winscp.net/eng/docs/guide_windows_openssh_server
Error message: Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended).
Command line ssh and scp work fine.
Log file:
Log file:
. 2017-02-04 10:51:58.135 -------------------------------------------------------------------------- . 2017-02-04 10:51:58.135 Using SCP protocol. . 2017-02-04 10:51:58.135 Doing startup conversation with host. . 2017-02-04 10:51:58.135 Session upkeep . 2017-02-04 10:51:58.135 Looking for network events . 2017-02-04 10:51:58.135 Detected network event . 2017-02-04 10:51:58.135 Enumerating network events for socket 1604 . 2017-02-04 10:51:58.135 Enumerated 1 network events making 1 cumulative events for socket 1604 . 2017-02-04 10:51:58.135 Handling network read event on socket 1604 with error 0 . 2017-02-04 10:51:58.135 Received 38 bytes (0) . 2017-02-04 10:51:58.135 Received 56 bytes (0) . 2017-02-04 10:51:58.135 Received 2 bytes (0) . 2017-02-04 10:51:58.135 Received 19 bytes (0) . 2017-02-04 10:51:58.198 Skipping host startup message (if any). > 2017-02-04 10:51:58.198 echo "WinSCP: this is end-of-file:0" . 2017-02-04 10:51:58.198 Sent 37 bytes . 2017-02-04 10:51:58.198 There are 0 bytes remaining in the send buffer . 2017-02-04 10:51:58.198 Looking for network events . 2017-02-04 10:51:58.198 Timeout waiting for network events . 2017-02-04 10:51:58.198 Read 40 bytes (75 pending) < 2017-02-04 10:51:58.198 Microsoft Windows [Version 10.0.14393] . 2017-02-04 10:51:58.198 Read 54 bytes (21 pending) < 2017-02-04 10:51:58.198 (c) 2016 Microsoft Corporation. All rights reserved. . 2017-02-04 10:51:58.198 Read 2 bytes (19 pending) < 2017-02-04 10:51:58.198 . 2017-02-04 10:51:58.198 Read 19 bytes (0 pending) . 2017-02-04 10:51:58.198 Waiting for another 1 bytes . 2017-02-04 10:51:58.198 Looking for incoming data . 2017-02-04 10:51:58.198 Looking for network events . 2017-02-04 10:51:58.198 Detected network event . 2017-02-04 10:51:58.198 Enumerating network events for socket 1604 . 2017-02-04 10:51:58.198 Enumerated 1 network events making 1 cumulative events for socket 1604 . 2017-02-04 10:51:58.198 Handling network read event on socket 1604 with error 0 . 2017-02-04 10:51:58.198 Received 1 bytes (0) . 2017-02-04 10:51:58.198 Received 12 bytes (0) . 2017-02-04 10:51:58.198 Received 24 bytes (0) . 2017-02-04 10:51:58.198 Read 1 bytes (36 pending) . 2017-02-04 10:51:58.198 Read 36 bytes (0 pending) < 2017-02-04 10:51:58.198 test@TEST C:\Users\test>echo "WinSCP: this is end-of-file:0" . 2017-02-04 10:51:58.198 Waiting for another 1 bytes . 2017-02-04 10:51:58.198 Looking for incoming data . 2017-02-04 10:51:58.198 Looking for network events . 2017-02-04 10:51:58.198 Detected network event . 2017-02-04 10:51:58.198 Enumerating network events for socket 1604 . 2017-02-04 10:51:58.198 Enumerated 1 network events making 1 cumulative events for socket 1604 . 2017-02-04 10:51:58.198 Handling network read event on socket 1604 with error 0 . 2017-02-04 10:51:58.198 Received 37 bytes (0) . 2017-02-04 10:51:58.198 Read 1 bytes (36 pending) . 2017-02-04 10:51:58.198 Read 36 bytes (0 pending) < 2017-02-04 10:51:58.198 echo "WinSCP: this is end-of-file:0" . 2017-02-04 10:51:58.198 Waiting for another 1 bytes . 2017-02-04 10:51:58.198 Looking for incoming data . 2017-02-04 10:51:58.198 Looking for network events . 2017-02-04 10:51:58.198 Detected network event . 2017-02-04 10:51:58.198 Enumerating network events for socket 1604 . 2017-02-04 10:51:58.198 Enumerated 1 network events making 1 cumulative events for socket 1604 . 2017-02-04 10:51:58.198 Handling network read event on socket 1604 with error 0 . 2017-02-04 10:51:58.198 Received 33 bytes (0) . 2017-02-04 10:51:58.198 Received 2 bytes (0) . 2017-02-04 10:51:58.198 Received 19 bytes (0) . 2017-02-04 10:51:58.198 Read 1 bytes (53 pending) . 2017-02-04 10:51:58.198 Read 32 bytes (21 pending) < 2017-02-04 10:51:58.198 "WinSCP: this is end-of-file:0" . 2017-02-04 10:51:58.198 Read 2 bytes (19 pending) < 2017-02-04 10:51:58.198 . 2017-02-04 10:51:58.198 Read 19 bytes (0 pending) . 2017-02-04 10:51:58.198 Waiting for another 1 bytes . 2017-02-04 10:51:58.198 Looking for incoming data . 2017-02-04 10:51:58.198 Looking for network events . 2017-02-04 10:52:14.586 Timeout waiting for network events . 2017-02-04 10:52:14.586 Waiting for data timed out, asking user what to do. . 2017-02-04 10:52:14.586 Asking user: . 2017-02-04 10:52:14.586 **Host is not communicating for 15 seconds. . 2017-02-04 10:52:14.586 . 2017-02-04 10:52:14.586 Wait for another 15 seconds?** () . . . . 2017-02-04 10:52:35.426 Attempt to close connection due to fatal exception: * 2017-02-04 10:52:35.426 **Terminated by user.** . 2017-02-04 10:52:35.426 Closing connection. . 2017-02-04 10:52:35.426 Sending special code: 12 . 2017-02-04 10:52:35.426 Sent EOF message . 2017-02-04 10:52:35.426 Selecting events 0 for socket 1604 * 2017-02-04 10:52:35.488 (EFatal) **Terminated by user.** * 2017-02-04 10:52:35.488 Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended).
