Intarnal Editor causes multi-byte character corruption
Jap
Internal editor causes multi-byte character corruption on WinSCP 5.9.3.
Conditions
- Shift-JIS(CP592) Encoding
- double-byte character near 2048th bytes from the beginning
I guess that WinSCP can not handle double-byte character across buffer boundaries correctly.
thank you.
Description: TestFile
Re: Intarnal Editor causes multi-byte character corruption
Can you post a test file before the corruption?
Jap
I attached the file before corruption to the first post.
Description: The test file view in the other text editor.
Jap
Jap wrote:
Add a corrupted view image for comparison.
The attached image above was a mistake. Correct.
Description: The test file view in the WinSCP internal editor.
