"+" replaced by " " on URL when running from CLI
First, I'd like to thank you this great tools I use everyday !
When WinSCP is launched from WinSCP.com or WinSCP.exe CLI, if a "+" is contained in the full URL (especially on username), it is replaced by a " " and authentication fails:
Here is an exemple with a Cygwin SSH Server (FYI: it's in french):
With WinSCP.exe, exact same issue.
I tried to escape + and various other workaround but without success.
WinSCP Version: 5.9.4 (Tried with recent but older version: same issue to)
OS: Windows 10 x64 Enterprise
-u argument used with cmd.exe doesn't change anything.
Hope this helps !
Regards,
AVB
C:\Program Files (x86)\WinSCP>winscp.com sftp://DOMAIN+USER:PASSWORD@SERVER.FQDN
Ouvrir une session en utilisant un paramètre de la ligne de commande est déprécié. Utilisez la commande 'open' à la place.
Recherche de l'hôte... (Searching for host)
Connexion à l'hôte... (Connecting to host)
Authentification... (Authentication)
Utilisation du nom d'utilisateur "DOMAIN USER". (Using the Username DOMAIN USER -Without '+' !-)
Authentification avec le mot de passe pré-entré. (Authentication with given password)
Accès refusé. (Access Denied)
Déconnexion inattendue Résultat de la commande exit sur le serveur 0 (Unexpected disconnection...)
Log d'authentification (voir le log de session pour les détails) (See log for more details)
Utilisation du nom d'utilisateur "DOMAIN USER". (Using username "DOMAIN USER")
Erreur d'authentification (Authentication failure)
Hope this helps !
Regards,
AVB
