Could not deliver the file to SFTP in windows automation but log is showing success
Kelly121
The file could not deliver to SFTP location but in Log file it is showing as success. I created a job through windows automation using below script.
cd %Root%
for /f %%a in (.\Jobs\Holidays.txt) do (
if %%a == %date:~-10,2%/%date:~-7,2%/%date:~-4% (
@echo off
cd "C:\Program Files (x86)\WinSCP"
winscp.com /log=C:\pa\Jobs\BlS\Log\winscp.log /script=Prod.txt
In Prod.txt I have used below.
option batch abort
open sftp://user:password@sername/ -privatekey="PuTTYPrivateKey.ppk"
put C:\TA\blS\BSN.txt /inbound/bsy/
EXIT
I have attached the log file. Could you please let me know what I am missing.
  • log.txt (8.9 KB, Private file)
Description: Log file for SFTP
Kelly121
Here i can think two options.
1. There are nothing specified in argument field.
2.There are some extra commands in my batch file like before running winscp command it will check holiday.txt file.
Please advise.
Thanks.
Re: Could not deliver the file to SFTP in windows automation but log is showing success
"The file could not deliver to SFTP location" - How do you check that?
Add ls /inbound/bsy before exit and post a new log file.
Kelly121
Client notified us that the file was not delivered. But the log was showing something different.
Kelly121
Hello Martin,
When I logged into the environment with provided password I found folder level permission was set in 555 i.e. r-xr-xr-x. Is it stopping the file to be delivered? If so then I wonder when we execute script manually then how the file gets delivered. Please advise,
Kelly121
Our client notified that the transmission is based on password based authentication only, no public key required. I used ls in the script. Log file was attached. Client did not receive the file but log shows Transfer done.
  • winscplog2.txt (10.11 KB, Private file)
Description: log file
The file is indeed not in the target directory, even though the upload succeeded.
On *nix server, the permissions "r-xr-xr-x" would indeed indicate, that you cannot write to the directory.
But it's some custom SFTP server, it may not be based on *nix, and the permissions it reports can easily be fake.
There's hardly anything more I can debug remotely. WinSCP uploaded the file, the server acknowledged the upload. The file is not there yet. It looks like a bug in the server to me (either it discarded the file for some reason; or it failed to report some error, that prevented the upload). I do not see anything wrong on WinSCP side.
Are you able to upload the file to their server anyhow? Using WinSCP GUI? Using any other SFTP client?
