TlsHostCertificateFingerprint not working when called from Powershell script
Dear WinSCP support;
I'm trying to write a WinSCP/Powershell script to connect a FTP server (TLS Explicit with untrusted certificate)
I have no problem to manually connect to this FTP server using the WinSCP graphical interface.
Here is the automatically generated Powershell code from WinSCP "Generate session URL/code" tool :
Since, this automatically generated code doesn't include the TLS Host Certificate, I get the following error message when I try to call it from a PS1 script :
So I tried to include the certificate fingerprint into the script, by setting the parameter :
I'm 100% confident that my certificate fingerprint is correct since it is the one indicated in "Server and protocol information" when I'm connected via WinSCP graphical mode.
Unfortunately this doens't work, when I run the script it gives the error message :
As anyone experience the same problem?
Thanks in advance for your help
howard
# Load WinSCP .NET assembly Add-Type -Path "WinSCPnet.dll" # Set up session options $sessionOptions = New-Object WinSCP.SessionOptions -Property @{ Protocol = [WinSCP.Protocol]::Ftp HostName = "xxx.xxx.xxx.xxx" PortNumber = 21 UserName = "xxxxxx" Password = "xxxxxx" FtpSecure = [WinSCP.FtpSecure]::Explicit } $session = New-Object WinSCP.Session try { # Connect $session.Open($sessionOptions) # Your code } finally { $session.Dispose() }
Error: Connection failed.
Server asks for authentication with a client certificate.
Peer certificate rejected
Disconnected from server
Connection failed.
# Load WinSCP .NET assembly Add-Type -Path "WinSCPnet.dll" # Set up session options $sessionOptions = New-Object WinSCP.SessionOptions -Property @{ Protocol = [WinSCP.Protocol]::Ftp HostName = "xxx.xxx.xxx.xxx" PortNumber = 21 UserName = "xxxxxx" Password = "xxxxxx" FtpSecure = [WinSCP.FtpSecure]::Explicit TlsHostCertificateFingerprint = "x:x:x:xx:x:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx" } $session = New-Object WinSCP.Session try { # Connect $session.Open($sessionOptions) # Your code } finally { $session.Dispose() }
Error: Authentication failed
howard
