WinSCP and PuTTY 0.68 64bit on MS Windows: File 'C:\Program Files (x86)\PuTTY\putty.exe' not found.
t603
Prague
Hello, Martin,
can I ask You, if WinSCP does or will support PuTTY 0.68+ 64bit on MS Windows out of the box? Currently on my 64bit MS Windows computer, WinSCP 5.9.2 after upgrading PuTTY to 0.68 64bit says
The path to PuTTY in WinSCP is
"%PROGRAMFILES%\PuTTY\putty.exe -t -m "%TEMP%\putty.txt" !`cmd.exe /c echo cd '!/' ; /bin/bash -login > "%TEMP%\putty.txt"`"
When I manually switch to
""C:\Program Files\PuTTY\putty.exe" -t -m "%TEMP%\putty.txt" !`cmd.exe /c echo cd '!/' ; /bin/bash -login > "%TEMP%\putty.txt"`"
... WinSCP works well, although "cd %PROGRAMFILES%" shows to "C:\Program Files".
I did not found any marks about PuTTY 0.68 nor PuTTY 64bit in WinSCP's Recent Version History page. Yes, I can stay in bot 32bit WinSCP and PuTTY, but I am just asking.
Regards, Stepan
Re: WinSCP and PuTTY 0.68 64bit on MS Windows: File 'C:\Program Files (x86)\PuTTY\putty.exe' not found.
Currently WinSCP does not support 64-bit version of PuTTY out-of-the-box. You have to reconfigure PuTTY path to point to 64-bit version, like you did.
Next version of WinSCP will support it.
