Connection has been unexpectedly closed. Server sent command exit status 0
Jaya
Hi I am using the belowcode to connect to SFTP Through WinSCP. It gets connected only once.Next time when I run the code I get the error at this line
"mySession.Open mySessionOptions"
connection has been unexpectedly closed. Server sent command exit status 0.Authentication failed
Please Help.
Option Explicit
Sub Connect_To_SFTP()
Dim mySession As New session
' Enable custom error handling
On Error Resume Next
Upload mySession
' Query for errors
If Err.Number <> 0 Then
MsgBox "Error: " & Err.Description
' Clear the error
Err.Clear
End If
' Disconnect, clean up
mySession.Dispose
' Restore default error handling
On Error GoTo 0
End Sub
Sub Upload(ByRef mySession As session)
Dim works As String
' Setup session options
Dim mySessionOptions As New sessionOptions
'bool GiveUpSecurityAndAcceptAnySshHostKey
With mySessionOptions
.Protocol = Protocol_Sftp
.HostName = "lab.com"
.UserName = "*****"
.Password = "******"
.GiveUpSecurityAndAcceptAnySshHostKey = True
End With
' Connect
' Upload files
Dim transferOptions As New transferOptions
'Set transferOptions = WScript.CreateObject("WinSCP.TransferOptions")
transferOptions.TransferMode = TransferMode_Binary
Dim transferResult
Set transferResult = mySession.GetFiles("/Result/Output_TXT/*", "c:\toupload\", False, transferOptions)
' Throw on any error
transferResult.Check
' Print results
Dim transfer
For Each transfer In transferResult.Transfers
Debug.Print "Download of " & transfer.Filename & " succeeded"
Next
mySession.Dispose
End Sub
martouf
Connection unexpectedly closed
Try following the thread of execution but focus only on the mySession variable.
Connect_To_SFTP()
Dim mySession
Upload( mySession ) -> passed by reference
Dispose mySession
Return to Connect_To_SFTP()
Dispose mySession
Return to <caller>
Jaya
Hello yesterday I did windows update. Now its giving me Automation error-2146234304
Please help me with this first.
so that i can check the above solution
martouf
sorry, but "the above" is not a SOLUTION but a big HINT of what the problem is likely to be.
i could be wrong, but a double DISPOSE is not likely to give good results.
in general, it is my understanding that good coding practice is to perform a Dispose only in the method or subroutine that performed the variable allocation ("Dim") -especially- if the variable is passed around by reference (and not by value).
Jaya
Try to unregister (!) and then re-register the .NET assembly.
https://winscp.net/eng/docs/library_install#registering
Hello I unregisterd using the command
SET WorkFolder= '<directory>'
regasm.exe /unregister %WorkFolder%\xxx.dll
And re registerd it.
Still getting the same error
Please help
Jaya
So you have some .exe file built from your code? Is it VB6?
No .exe files.Have .tlb and .dll files.
It's VB 7.1.
Jaya
Sorry, I have no idea how VB works. So again, do you build some .exe from your code? Or how do you run it?
Calling Winscp.exe and COM object accessing Microsoft .NET framework.
Jaya
I have restored the system.Now no automation error.
Please help me with this.
I am using the above code to connect to SFTP Through WinSCP. It gets connected only once.Next time when I run the code I get the error at this line
Please Help.
Please Help.
Please attach a full session log file for both sessions (using the latest version of WinSCP).
Jaya
Please Help.
i have attached the code.
Registered regasm.exe using commands
"%WINDIR%\Microsoft.NET\Framework\v4.0.30319\RegAsm.exe WinSCPnet.dll /codebase /tlb:WinSCPnet32.tlb"
"%WINDIR%\Microsoft.NET\Framework64\v4.0.30319\RegAsm.exe WinSCPnet.dll /codebase /tlb:WinSCPnet64.tlb"
Jaya
There's no log file attached to your post.
what are log files?. I'm new to VBA I don't know what are log files.
Read my previous post carefully again!
