/script not firing
lbrewerton
/script not firing
I have a Windows CMD file -
@echo off
start "C:\Program Files (x86)\WinSCP\WinSCP.exe" /script=C:\HyveSync\Automation\KBStaffSync.txt /xmllog=C:\HyveSync\Automation\log.txt
The script file is this:-
# Automatically abort script on errors
option batch continue
# Connect using stored connection
sftp://KBStaff
# Force binary mode transfer
option transfer binary
synchronize remote C:\Tomcat\Websites\Shared\staffwiki /kbstaff
# Disconnect
close
But when I fire the CMD file either by using the shortcut or from command line, nothing seems to happen and my log file is empty, but if I use the WinSCP console and copy/paste the commands from the script file into the WinSCP console then it works fine.
Re: /script not firing
Your code cannot work in any way. This is just wrong: sftp://KBStaff. You probably wanted open sftp://KBStaff. But still, you are missing credentials.
https://winscp.net/eng/docs/scriptcommand_open
https://winscp.net/eng/docs/session_url
And you should use the winscp.com, at least for debugging. With winscp.exe you cannot see the errors.
https://winscp.net/eng/docs/executables
lbrewerton
This is using a stored connection so connection details should not be necessary?
When I use winscp.com I get a "no mapping for the unicode character exists in the target multibyte code page" error
But you still need the open command.
And using stored sites in the script is not recommended:
https://winscp.net/eng/docs/scripting#configuration
Make sure the script uses UTF-8 encoding.
