filemask using days, e.g *>=1D Is 1D = 24 hours or just the calendar day prior?
dbabmr
If I use -filemask="*>=1D", does that compare just the day component of time, or does it compare using 24 hours? Example, if source file was created 25 hours ago at 7am my time yesterday, if I do a get using *>=1D", will that file get picked up? The date is one day old, but the time is more than 24 hours ago. Thanks.
felixramses
Mask is invalid near 'yesterday'
Hello, I'm making a batch that downloads the files with last modification of the previous day. When I use the 1DS mask or 'yesterday' when I run it it sends me a message that it is invalid. It only lets me use it with 1D but this doesn't work for me.
the part of the instruction that fails is the following:
get "/CONV/*.gz>yesterday" "C:\FILEBASE\FILE\DAILY\LANDING\"
or
get "/CONV/*.gz>1DS" "C:\FILEBASE\FILE\DAILY\LANDING\"
Re: Mask is invalid near 'yesterday'
You probably have an old version of WinSCP, which does not support the S suffix yet. Make sure you have the latest version.
rico
France
I start with Winscp and I do not understand why my filemask does not work. I would like with this option upload to my local computer, files having my 10 days being on my seedbox.
# Automatically answer all prompts negatively not to stall
# the script on errors
option batch on
open ftp://xxxxxxxxxxxxxxxxxxxxnet
# Force binary mode transfer
option transfer binary
# Interface 1
cd /Downloads
lcd "C:\temp"
#Copy and filter
get -filemask ="*>=10D"
# Disconnect
#close
# Exit WinSCP
But in return he tells me that they do not find matching files ... While there are ...
If i do get *.* no problem, but with filter doesn't work
Do you have an idea?
Thank you.
sorry for my English ;-)
