VBA --- Timeout waiting for WinSCP to respond
I've implemented WinSCP .NET Assembly for VBA, trying to upload files from a local folder through SFTP, but I'm getting "Timeout waiting for WinSCP to respond" when I try to upload a number of files bigger than 150 - 200.
Of course, I've tried using .TimeoutInMilliseconds and I've increased it and tested even with 900000.
If I transfer only 100 files, it's ok with values much much lower than 900000. BTW, what is the MAX value for TimeoutInMilliseconds?
When I get the timeout error, it fails without transferring any file, so this makes me understand that it fails at the part when WinSCP evaluates the number of files & dimension it has to transfer, before starting the transfer.
The files are .zip and have in average 110 KB, so the transferred values are not so big, between 20MB-45MB per day.
With mySessionOptions
.Protocol = Protocol_Sftp
.TimeoutInMilliseconds = 600000
.HostName = "xx.xxx.xxx.xx"
.UserName = "xxxxx"
.GiveUpSecurityAndAcceptAnySshHostKey = True
.SshPrivateKeyPath = "C:/xxxx/PrivateKey.ppk"
End With
And the transfer is done like:
' Upload files
Dim myTransferOptions As New TransferOptions
myTransferOptions.TransferMode = TransferMode_Binary
Set transferResult = mySession.PutFiles("\\local\path\*", "/in/", False, myTransferOptions)
Thanks in advance for your advices.
Re: VBA --- Timeout waiting for WinSCP to respond
Please attach a full session and debug log file showing the problem (using the latest version of WinSCP).
To generate the log files, set Session.SessionLogPath and Session.DebugLogPath. Submit the logs with your post as an attachment. You may want to remove data you consider sensitive (unless they are relevant to the problem). If you do not want to post the log publicly, you can mark the attachment as private.
We need corresponding debug log files too. See my previous post.
Try to run just a simple script file like:
winscp.com /log=session.log /ini=nul /script=script.txt
with script.txt:
open "sftp://user@xx.xxx.xxx.xx" -hostkey="*" -privatekey="C:/xxxx/PrivateKey.ppk" -timeout=600
put  -nopermissions -preservetime -transfer="binary" -- "\\xxxx\*" "/in/"
What does it do? Post a log file.
I think I solved the problem. It was on server side, due to automatic transfer resume.
"With SFTP protocol, when automatic transfer resume is enabled, WinSCP first uploads the file to a temporary file with .filepart extension. Only after the transfer is completed the file is renamed to its actual name."
I've deactivated this, and I live the VBA code here, for future uses:
TransferOptions.ResumeSupport.State = TransferResumeSupportState.TransferResumeSupportState_Off
Thanks, Martin, for all your help.
