Synchonize activity?
Is there a way to set it up such that what I do on the local end is mirrored on the remote end?
In other words, if I change directories on the local side, they directory changes to the same one on the remote side. If I delete a file locally, it deletes it remotely.
Thank you for your help, anyone!
-Geoff
-Geoff
