Synchronising the folders
upatil
I am new to WinScp, it is installed on my PC C:\Program Files (x86)\WinSCP
I need to Synchronize folder say C:\OpenLABProjects daily on XYZ server. As my server is being backed-up, data will be moved from my PC to server and then finally in Tape.
I need a batch file, which will daily at scheduled time using windows scheduler. Any changes (like files or folders) from source folder C:\OpenLABProjects should move to destination folder@XYZ server.
I have installed WinSCP 5.9.4 (build 7333), please help. Appreciate your support
upatil
My command file
C:\OpenLAB_FileTransfer\Scripts\WinSCP\winscp.com /script=C:\OpenLAB_FileTransfer\Wipro\Automation\ftpscript.txt
ftpscript.txt
option batch continue
open geelopenlab@bp1xeuap3064
lcd C:\OpenLABProject
synchronize remote "C:\OpenLABProject" "\OpenLABProject\"
Output is showing below
C:\>C:\OpenLAB_FileTransfer\Scripts\WinSCP\winscp.com /script=C:\OpenLAB_FileTra
batch continue
confirm off
Searching for host...
Connecting to host...
Authenticating...
Using username "geelopenlab".
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] geelopenlab@BP1XEUAP3064
C:\OpenLABProject
Comparing...
Local 'C:\OpenLABProject' => Remote '\OpenLABProject\'
Synchronizing...
But I don't see folders and subfolders are synchronized
Re: Synchronising the folders
upatil wrote:
My command file
ftpscript.txt
Comparing...
Synchronizing...
>> what is the output followed? Synchronize will compare timestamp or size before performing transition. Could that be a cause to do nothing?
>> And it could be more helpful if you enable log and put log here.
The first problem is probably that you remote path syntax is wrong. You should use forward slashes, like /OpenLABProject. Basically, make sure you use the same syntax, you see in WinSCP GUI, if you navigate to the target folder.
If that does not help, please attach a full session log file showing the problem (using the latest version of WinSCP).
