STP - File upload timed out when working with large numbers of files.
I'm using WINSCP .net assembly to download large numbers of files. It works fine when number of files are less ( few hundreds) but it is getting timed out at session.GetFiles or while enemurating remote files if the number of files are too much (few thousands). Could you please suggest some fix or work around. log files are attached for your reference.
