Setting "session timeout?"
cara
Our vendor just moved us to a new SFTP server, and I'm now having intermittent issues with downloads that had been working.
I'm attaching the powershell script where I thought that adding
$session.Timeout = new-timespan -minutes 5
would do the trick, but apparently I'm guessing wrong!
I'm also attaching the debug log file, showing a 15 second timeout, I think.
What's the correct way for me to, as the vendor recommended, "...increase the time out in winscp..." ?
thanks
  • PowerShell_Script.txt (5.4 KB, Private file)
  • 20170316-1207_SessionDebug.log (121.55 KB, Private file)
Re: Setting "session timeout?"
I cannot see any timeout in the log.
Anyway, you probably want this:
(You actually have it already in the code, just commented-out).
cara
Thanks again, Martin.
I think I had that line commented out because I wasn't sure it was the right way to do it -- but I didn't realize I had NO method in use, so I appreciate the pointer!
I'm trying again with tonight's scheduled run.
