Error 0xc0000006 on Windows 10
wdonovan
New York
The following error occurs when starting WinScp.exe.
The application was unable to start correctly (0xc0000006).
Version 5.9.4 Build 7333
Windows 10 64-bit
Protocol: SFTP
This has worked in the past on this PC. However it no longer does.
Re: Error 0xc0000006 on Windows 10
wdonovan
New York
Error report
I ran the debug version on the affected PC but no error occurred. It worked as expected. The original version (non-debug) still produces the error. Debug log attached. I noticed the debug version is 5.10 but the original version we use is 5.9. Could that be the issue?
bbrennetot
The application was unable to start correctly (0xc0000006) on W7
I have the same problem for about 10 days but in a different context. The winscp.exe (5.1.7.3446) program was placed on a network share and is used on the command line to access sftp folders.
For a few days, as soon as we launch winscp.exe from some PCs under windows 7, we get the error message "The application was unable to start correctly (0xc0000006).". Yet we have not changed anything for several months.
However, if we copy the same file to the local machine, it works perfectly. We tried to uninstall the latest Windows updates, disable the Kaspersky antivirus, move the program on another server, download the latest version of winscp (5.9.4.7333) but the problem persists.
Moreover, I can't get logs, since all the options passed as parameters of the launch of the exe are not taken into account, the error message is displayed before.
Could you help me, please?
Re: Works!
wdonovan wrote:
The new development build seems to work fine.
Thanks for your feedback. Though it's actually strange.
Re: The application was unable to start correctly (0xc0000006) on W7
bbrennetot
Paris
My mail sent
I created an account with the same username: bbrennetot
I sent you an e-mail.
Thank you in advance for your help
bbrennetot
Paris
Unable to generate log file
The WinSCP1F5Ctrace.log file does not generate on the network share while I have the right to write. I also added a WINSCPTRACE environment variable to my local disk c:\ but no result.
The error message appears as soon as I start Winscp.exe or Winscp.com.
But everything works fine when I copy the folder that contains the Winscp.exe on my local drive. Winscp starts and the trace file is generated.
I don't understand where this problem comes from.
jackaision
United States
Error 0xc0000006 errors might be caused by many reasons, especially bad registries or Trojan infection. Then you will find that your Opening programs will be slower and response times lag as well.
Besides, If you run several program at the same time, your PC will encounter sudden crash and unexpected freezes. The main source of these performance decreases are startup clutter, registry errors, RAM decline, fragmented files, unnecessary or redundant program installations, etc.
Fix for this issue:
1. Hold down the “Windows Key” and press “R“.
2. Type “regedit” then press “Enter“.
3. Navigate to the following location:
HKEY_LOCAL_MACHINE > SOFTWARE > Wow6432Node > -Microsoft > WindowsNT > CurrentVersion > Windo¬¬ws
4. Open “AppInst_DLLs” and set it to a blank value.
5. Restart the computer.
