WINSCP stuck at sending files via BAT file.
anandvarkeyphilips
Hi Team,
Winscp is really good and free. Thank you for this first of all. My Winscp gets stuck at ear moving when i call the bat file with below code.I want to move ear and jar parallelly to different servers inorder to save time. Please advice.
@echo off
echo Setting path...
PATH=C:\Users\1509967\Documents\DOD\apache-ant-1.8.4;C:\Users\1509967\Documents\DOD\apache-ant-1.8.4\bin;C:\Users\1509967\Documents\DOD\jdk1.6.0_26\bin
echo.
echo Moving to scripts directory for execution...
cd C:\Users\1509967\Documents\DOD\SIT_934\scripts
echo.
echo Building...
call ant -buildfile BuildEar.xml
echo.
cd C:\Program Files (x86)\WinSCP
start  call winscp.com /command "open sftp://username:password@99.99.99.99/directory" "put -permissions=777  "C:\Build\destination\ear\project.ear"" "close" "exit"
start call winscp.com /command "open sftp://username:password@11.11.11.11/directory" "put -permissions=777 "C:\Build\destination\jar\project.jar"" "close" "exit"
pause
Re: WINSCP stuck at sending files via BAT file.
You have quotes wrong.
See https://winscp.net/eng/docs/commandline#syntax
Also it does not make sense to use call to run WinSCP. Also the first argument to start should be console window title.
start "title" winscp.com /command "open sftp://username:password@99.99.99.99/directory" "put -permissions=777 ""C:\Build\destination\ear\project.ear""" "close" "exit"
Or simply (as there are no spaces in the path):
start "title" winscp.com /command "open sftp://username:password@99.99.99.99/directory" "put -permissions=777 C:\Build\destination\ear\project.ear" "close" "exit"
