Sync only at night - Graceful stop or Pause function
savva
I would like to know if there is anyway to schedule the script to only run at night for example 2am-6am.
I have created a scheduled task and it works properly but I want it to stop at 6am. I know you can force the script to end using Scheduled task but i'm wondering if there is a more graceful way of stopping it. For example after a certain time for it to finish the last transfer its doing and then stopping.
The reason why i would prefer not killing the transfer is more of a corruption issue on the files. So far WinSCP has done a great job at resuming and continuing the transfer.
Any suggestions are welcomed.
Thanks.
Re: Sync only at night - Graceful stop or Pause function
No, there's no such option.
You would have to implement the synchronization manually using WinSCP .NET assembly.
