get -delete *.* problem in version 5.9.4
Martin Zazvorka
I found that command:
get -delete *.*
do not delete files in version 5.9.4 (in version 5.7.7 it works fine)
get -delete test.txt is OK, but mask for all files does not work.
Thank you very much for you program.
Martin Zazvorka
(Czech Republic)
Re: get -delete *.* problem in version 5.9.4
Please attach a full session log file showing the command from both versions of WinSCP.
Martin Zazvorka
Hello Martin,
I am sorry, it seems that it is some problem with our SFTP server, I tried script with another one and it works fine.
But I don't know reason, in log file everything looks fine.
Martin
  • BISIdownload-proWinscp.log (11.53 KB, Private file)
Description: v logu vypada vse v poradku, ale soubor po ukonceni na SFTP serveru zustava
Martin Zazvorka
Next 2 log files.
  • 20170408-BISIdownloadonly1file.log (12.21 KB, Private file)
Description: when is used exact filename, file deleted
  • 20170408-BISIdownload-vcetneLS.log (13.08 KB, Private file)
Description: with LS to show that file is still there
Indeed, everything looks correct in the log.
WinSCP requested the file deletion and the server acknowledged it. There's nothing wrong on WinSCP side.
It must be the server. Did you check its log file?
Also, you can try to upgrade the server (the latest version is 7.29, you are using 6.45).
