Invalid pointer operation - WinSCP 5.9.4
adriaanh
WinSCP version 5.9.4 on Windows Server 2012 R2 Hyper-V virtual machine
Transfer protocol: SFTP
We do a scripted transfer of 2 files daily, 4 and 5 GB per file. It works 1 or 2 times per week, the other transfers fail.
The script:
open sftp://{user}:{password}@{servername}/ -hostkey="ssh-rsa 2048 {hostkey}" -rawsettings SendBuf=0
put -resumesupport=on C:\Backups\{file1} /backup/
put -resumesupport=on C:\Backups\{file2} /backup/
The error:
Searching for host...
Connecting to host...
Authenticating...
Using username "{user}".
Authenticated.
Starting the session...
Session started.
Active session: [1] {user}@{servername}
C:\Backups\{file1} |     3926170 KB | 52818.3 KB/s | binary |  76%
expected key exchange reply packet from server
(A)bort, (R)econnect (5 s): Reconnect
Authenticating...
Authenticated.
Session started.
C:\Backups\{file1} |     3987711 KB | 53391.3 KB/s | binary |  77%
C:\Backups\{file1} |     4137138 KB | 39099.2 KB/s | binary |  80%
Authenticating...
Authenticated.
Session started.
C:\Backups\{file1} |     4160955 KB | 39989.7 KB/s | binary |  80%
Please help us improving WinSCP by reporting the error on WinSCP support forum.
(003E36F4)
(003E36F4)
(00866B09)
(008688B7)
(0075B7EC)
(0075A90A)
(00787619)
(006EEB85)
(006E9803)
(006EAB76)
(00053F97)
(0005A43A)
(000D640A)
(000024A8)
(00864B95)
(00059B8D) ntdll.dll
(00059B55) ntdll.dll
Re: Invalid pointer operation - WinSCP 5.9.4
adriaanh
Hi Martin,
The company that manages the server has installed a new server with up-to-date software. We don't have the same issues with the new server.
Thanx for your help!
(00BEB625)
(00F85626)
(00F8768E)
(00F84448)
(000852DF) ntdll.dll
(00072BE1) ntdll.dll.KiUserExceptionDispatcher
(00BE9D67)
(00BE9F5C)
(00BFCD8D)
(00BCB916)
(00BCBA09)
(00D05F1C)
(00D04DFF)
(00CFFDBD)
(00CFF6FD)
(00D875FD)
(00CF2812)
(00CFBFCE)
(00CEFBED)
(00CF117F)
(00060E73)
(00068873)
(001001F1)
(00002658)
(00F83639)
(000664EB) ntdll.dll.RtlGetAppContainerNamedObjectPath
(000664B8) ntdll.dll.RtlGetAppContainerNamedObjectPath
Using username "tda_p_tda".
Authentication failed.
at WinSCP.SessionLogReader.Read(LogReadFlags flags)
at WinSCP.ElementLogReader.Read(LogReadFlags flags)
at WinSCP.SessionElementLogReader.Read(LogReadFlags flags)
at WinSCP.CustomLogReader.TryWaitForNonEmptyElement(String localName, LogReadFlags flags)
at WinSCP.CustomLogReader.WaitForNonEmptyElement(String localName, LogReadFlags flags)
at WinSCP.Session.WaitForGroup()
at WinSCP.Session.Open(SessionOptions sessionOptions)
at FTPProcess.FTPOpr.SFTPGetFiles(String filePattern) in C:\Users\spabbu\source\Workspaces\DTS-Web\Main\TDAmeritrade\TDA.LeadGen.NewsLetter.DownLoad\FTPProcess\FTPOpr.cs:line 48
at TDA.LeadGen.NewsLetter.DownLoad.Program.Main(String[] args) in C:\Users\spabbu\source\Workspaces\DTS-Web\Main\TDAmeritrade\TDA.LeadGen.NewsLetter.DownLoad\TDA.LeadGen.NewsLetter.DownLoad\Program.cs:line 36
Logger: TDA.LeadGen.NewsLetter.DownLoad.Program
RequestURL: (null)
Thread: 1
Date: 2021-04-08 19:55:03,538
NDC: (null)
