Topic "Custom command to download remote selected file to a specific local directory"
onirix
I’d like to have a custom command to download a copy of a remote file to a predefined local path.
In a second time I’d like to add a prefix to the copied file with "VM-".
Here is my command that does not work :
winscp /command get !& c:\Users\myName\Desktop\TEMP\
I join screens
Thx for your help ! Cool
2017-04-14 11_08_55-Editer une commande.png (30.6 KB)
Description: Custom command editing
2017-04-14 11_07_44-configuration - VM EGSI - WinSCP.png (33.47 KB)
Description: Context menu
I assume that this is your question:
https://superuser.com/q/1200472/213663
onirix
Thanks a lot Martin for your response.
I didn’t found this post on SuperUser website!
So the only way to script something like that using the is to get command is to go through by the WinSCP console, isn't it ?
Can I send a parameter like the file to download from the contextual menu to the console ?
It’s much complex that I’ll think at the first sight Confused
I really though that's it's your question.
But now I see that it somewhat different.
What you are trying is the right approach, but you also need to open the session. And your syntax is wrong.
winscp /command "open !S" "get !& c:\Users\myName\Desktop\TEMP\*" "exit"
See
https://winscp.net/eng/docs/guide_custom_commands_automation
https://winscp.net/eng/docs/commandline
