check .txt file exists or not in remote server if exists and then download via winscp
Zuk
Hi All,
Could you please help on the below scenario
I want check *.cnf file exists or not on the remote server
If exists download the *.csv files ? if not exit from prompt.
This I am looking to do via winscp with batch script only
Could you please help.
[/quote]
Re: check .txt file exists or not in remote server if exists and then download via winscp
Sorry, but we are no a code writing service. Do you have any particular problem?
More over it's not clear, what you want. Do you want to download all *.csv files, if any *.cnf file exists? Or do you want to download those .csv that have corresponding .cnf?
