Cannnot remove remote file
Robert324
I am using WinScp net for long time. Now i am developing on new machine and created testing ftp. However for unknow reason this time i cannot remofe file from remote location. Don't know why. There is no error message, but when using RemoveFile method IsSuccess is false
I can download files from this ftp, check whether they exist but if it comes to removeFile method i get false for IsSuccess without any error. What could be a problem here? As i said on diffrent machine this works as well. How to investiaget that?
 Function FileExist(path As String) As Boolean
        Dim result As Boolean
        If session IsNot Nothing Then
            result = session.FileExists(path)
        Else
            result = False
        End If
        Return result
    End Function
If FileExist(path) Then
   Dim removalResult As RemovalOperationResult = session.RemoveFiles(path)
       If removalResult.IsSuccess = False Then
          result = False
       End If
End If
Re: Cannnot remove remote file
Did you really check, that the removalResult.Failures(0).Message is empty?
