50x slower then cyberduck/filezilla need help to fix
ryanperkins153
I took a screenshot of a download of the same zip file using cyberduck and winscp
winscp is like 50x slower then cyberduck and same with filezilla
can someone tell me what is wrong
I like using winscp but the speed makes it useless and very time consuming to work effectively
screenshot = <invalid hyperlink removed by admin>
Re: 50x slower then cyberduck/filezilla need help to fix
Don't you have a verbose logging enabled in WinSCP?
Do you get the same problem, if you download the file to the same folder as CyberDuck is downloading it to?
