Bat file opening session but will not transfer files
donnette
Denver, CO
My bat file opens the session but will not move the files. The commands are below
winscp.com /ini=nul /command^
open ftp:@hostkey----this works fine
put -latest Z:\ARExtract\outgoing\* /inbound/test/arextract
Can anyone help me solve?
Thank you,
Donnette
Re: Bat file opening session but will not transfer files
winscp.com /ini=nul /command ^
    "open ftp://username:password@host/" ^
    "put  -latest Z:\ARExtract\outgoing\* /inbound/test/arextract/" ^
    "exit"
Use Generate Code function to have WinSCP GUI generate a batch file template for you:
https://winscp.net/eng/docs/ui_generateurl#script
