Timeout detected. (control connection) - Copying files to remote side failed
I am been using Core FTP LE for ftp file transfers and have just discovered WinSCP. WinSCP is a far nicer program, but unfortunately on occasions get “Timeout detected. (control connection) - Copying files to remote side failed.” errors when copying files to the remote server.
Everything else works okay and problem only appears to be the copying of files that cause a problem. There is just no definitive pattern as sometimes it works and other times it does not. It does not matter if the files are small or large, ASCII or binary or copying to different directories, one day is fine and another is not. Tried adjusting the settings but still the same.
Core FTP always works and has never suffered from timeout problems.
Logs for both in attached ftplogs.txt.
Description: Logs for WinSCP and Core FTP LE
Thanks dma_k, disabling passive mode looks to have solved it. Did a bit of test copying and problem never surfaced. Thanks again.
Update.
Despite the last few days working - and fine earlier in the day - encountered problem again with Passive mode disabled. Transferring two files, the first was okay and the problem happened about a quarter of the way for the second. Countless reconnecting and trying again no joy, and had to use Core FTP LE.
It appears that at certain times something is happening that causes a problem for WinSCP but cannot see what it is.
For reference, the final part of the log to show differences for not using Passive mode:
> 2017-05-04 14:15:29.697 TYPE A
< 2017-05-04 14:15:29.712 200 Switching to ASCII mode.
> 2017-05-04 14:15:29.713 PORT 10,0,208,136,248,13
< 2017-05-04 14:15:29.728 200 PORT command successful. Consider using PASV.
> 2017-05-04 14:15:29.729 STOR xxxxxxxxxx.txt
. 2017-05-04 14:15:44.506 Timeout detected. (data connection)
. 2017-05-04 14:15:44.507 Copying files to remote side failed.
. 2017-05-04 14:15:44.508 Connection was lost, asking what to do.
. 2017-05-04 14:15:44.508 Asking user:
. 2017-05-04 14:15:44.508 Lost connection. ("Timeout detected. (data connection)","Copying files to remote side failed.")
* 2017-05-04 14:15:45.510 (ESshFatal) **Lost connection.**
* 2017-05-04 14:15:45.510 Timeout detected. (data connection)
* 2017-05-04 14:15:45.510 Copying files to remote side failed.
Re: Timeout detected. (control connection) - Copying files to remote side failed
The kernel of our server has just been updated, and although I have not really had chance to really test it the timeout problem seems to have gone away.
The previous version was:
Red Hat Enterprise Linux Server release 6.7 (Santiago)
Kernel 2.6.32-573.el6.x86_64 on an x86_64
Version now:
Kernel 2.6.32-754.el6.x86_64 on an x86_64
It may be that it is in a good phase at the moment, but if the Linux/Kernel version was the cause then hope you find this information useful.
(originally sent by OP to the Admin by email)
Boatbodger
Control connection timeouts
In my case, I was sending big-ish files (700kB) to a small microcontroller-based device with the file being stored in FLASH memory. The FTP server running on this device could only handle a 1k windows size, and scheduling 'ticks' meant it could only handle about 8 windows' worth per second. On the Windows PC, there was clearly outbound buffering going on which seemed to be absorbing roughly 400kB. That all meant that after WinSCP had "sent" its final block, there were still around 30 seconds worth of data to be sent at the TCP layer, and WinSCP was timing out – not realising packets were still hurtling back and forth.
To resolve this, I increased the "server response timeout" (advanced settings in the connection, then 'Connection' then part way down the screen 'Timeouts'). I set it to 60 seconds, and can see on Wireshark that the residual data was taking about 35 seconds to get across, after which the server sends the 'Transfer Complete' response.
