method to check if ftp server is available?
George A.
Hello.
Is there a way to check if ftp server is available before sending ftp command to it?
Session.Opened member does not provide server status.
I tried stopping ftp server between requests, and it seems like there is no way to detect if it is available.
The way I see it is to create another instance of the Session object and try to open it...
If I stop server with live connection, component hangs at this method "ElementLogReader.Read(LogReadFlags flags)" or this one "SessionElementLogReader.Read(LogReadFlags flags)"...
Any suggestions?
thank you.
Re: method to check if ftp server is available?
It does not hang. It should timeout eventually.
George A.
never mind
thank you.
The point was to check if internet, server, and network are available before sending command or creating connection. i have solved the problem by writing my own code.
thank you anyway.
