Possible docs bug - https://winscp.net/eng/docs/integration_putty
user564758
In this guide there is a command for PuTTY to cd in to the current dir.
kitty.exe -cmd "cd ""!/"""
This works fine until my path has Unicode characters.
It appears that when a path has these characters WinSCP wraps them in double quotes independently of the command which then breaks the command.
Using the command in this path:
Sigur Rós - Með suð í eyrum við spilum endalaust
Gives this error.
If I change the command to this it appears to fix the issue:
-cmd "cd '!/'"
I can now successfully launch KiTTY and cd into any directory I like included paths with spaces and or Unicode characters.
Re: Possible docs bug - https://winscp.net/eng/docs/integration_putty
It's not the Unicode, but the space. But anyway, you are right.
I have edited the documentation. Thanks for your post.
