batch to download montly files from a linux server
lexxx25
hello,
we have a engine who generates joblogs on a linuxserver and put them all in a directory. i need those files for a monthly evaluation, so i have to copy them in the beginning of the new month on my windows laptop and run a vbs script to generate a xlms file.
now i try to make this by script.
this is what i have done till now
my batchfile:
@echo on
color f1
title MP14
set CURRENTTIME=%TIME%
set Filename=MP14-%DATE:~3,2%-%DATE:~6,4%
mkdir MP14
c:\"Program Files (x86)"\WinSCP\winscp.exe /console /script=winscp.txt
complete_xml.vbs c:\MP14 c:\%Filename%.xlsx
pause
and the winscp.txt file
option batch on
open sftp://username:password@IP-Adress
get -filemask=*>=2017-02-01<=2017-02-30 /var/opt/logs/* c:\MP14\
close
this works fine,but in this case i have to adjust the filemask each month.
my questing now: is there a filemask to say winscp "copy all files from the last full month?" or do anybody know an other way to fix my problem?
for example:
at the 2th of May i need the Files from April. or at the 5 of June i need the files from May.
thanks for help
Lexxx25
Hello Martin,
thanks for your post. I test this, but it didn't work.
option batch on
get -filemask=*>=%TIMESTAMP-28D#yyyy-mm-01%<%TIMESTAMP#yyyy-mm-01% /var/opt/logs/* c:\MP14\
close
when i run the script with this .txt file, i will get all files started on 28.04.2017 (thats okay, because the engine didn`t work on 29.4 and 30.4) backwards to the oldest file somewhere in 2015. :?
regards lexxx
Lexxx25
me again.
strange thinks happens :shock:
i do some more tests, but well, if i use this txt, winscp copy "some" files.. (we have round about 700000 files in that directory-3960 for april 2017). sometimes the script copy 156 files with dates trough the complete year (8 for april 2017). start it again 1 minute later without change anyting on script or directory it copy only 80 files with dates trough the whole year (2 for april 2017). 5 minutes later, without change anything, only 10 files will be copied, all from 2016.
using the .txt
option batch on
get -filemask=*>=2017-04-01<=2017-04-30 /var/opt/logs/* c:\MP14\
close
3960 from april 2017 will be copied.
do you have any ideas? or is it possible to start the script with date-parameters?
regards
Please attach a full session log files showing the problem for at least two consecutive runs (using the latest version of WinSCP). Include your description of the tests.
Lexxx25
Hello Martin,
well, after using the aktuell version of WinSCP and after some restarts of both engines, the script works perfekt.
thank you very much for your help.
Regards Lexxx
