Scheduled upload doesn't work from .bat file, Win 2012 R2
yoku
I have a .bat file with something like this:
@echo off
title Backup
SET logfile=C:\backup\Backup.log
echo ------------------------START Backup------------------------ >>%logfile% 2>&1
date /T  >>%logfile% 2>&1
time /T >>%logfile% 2>&1
if not exist "C:\Backup" mkdir C:\Backup
if not exist "C:\Backup\Archive" mkdir C:\Backup\Archive
echo -----copy----- >>%logfile% 2>&1
xcopy C:\\design\* C:\Backup\design\* /y /s
del /F /Q c:\AIC_Backup\Archive\*
"c:\backup\7-Zip\7z" a -r C:\Backup\Archive\Backup.7z C:\AIC_Backup\*
echo errorlevel: %ERRORLEVEL%
IF %ERRORLEVEL% == 0 GOTO OK
echo.
echo !!! ERROR There was a problem during zip procedure. ErrorLevel = %ERRORLEVEL%
echo.
GOTO end
:OK
echo ------------------------Archive Done------------------------ >>%logfile% 2>&1
echo ------------------------Start Uploading------------------------ >>%logfile% 2>&1
"c:\Program Files (x86)\WinSCP\winscp.com" /command "open sftp://root:root@server/" "put c:\Backup\Archive\Backup.7z /data1/backup/Backup.7z" "exit" "/log=Backup.log" "/loglevel=1"
echo ------------------------Uploading Done------------------------ >>%logfile% 2>&1
:end
echo ------------------------Backup Done------------------------ >>%logfile% 2>&1
Working cool, if I run it manually, but unfortunately scheduled task doesn't upload it. Archive is done, just WinSCP upload is not working. There is no log records for uploading (only if I run it by hand). Can anybody help me? Thanks
yoku
+ info:
If I try to run it from Task Scheduler, it runs but doesn't execute the winscp command. So it's working only if I double click on backup.bat.
If the batch file does not even execute WinSCP, it's not WinSCP question/problem.
If the actual problem is, that WinSCP is executed, but does not work, see
My script works fine when executed manually, but fails or hangs when run by Windows Scheduler, SSIS or other automation service. What am I doing wrong?
You are for sure missing the -hostkey switch, what is covered in the FAQ above and also here:
https://winscp.net/eng/docs/scripting#hostkey
yoku
Hi Martin,
Thanks a lot, it's a good starting point. At first, config was read out from registry. Now I exported settings to .ini and moved into WinSCP folder.
. 2017-05-09 13:01:22.093 Configuration: c:\backup\WinSCP\WinSCP.ini
Also I exported pub hostkey with ssh-keyXXXgen -l -f /etc/ssh/ssh_host_rsa_key.pub and put it in the command:
"c:\backup\WinSCP\winscp.com" /command  "open sftp://root:root@server/ -hostkey=""ssh-rsa 2048 1g:f3:e2:bc:35:ff:19:2f:a6:6f:d1:82:e6:af:1c:9c""" "put c:\AIC_Backup\Archive\AIC_Backup.7z /data1/backup/AIC/AIC_Backup.7z" "exit" "/log=AICBackup.log" "/loglevel=1"
The shown key is the same as the GUI shows before first connect e.g: https://winscp.net/eng/data/media/screenshots/unknown_hostkey.png
But scheduled task still doesn't work :( No log records for winscp command, just from .bat (>>%logfile% 2>&1). In attachment I uploaded the log when I run it with clicking on backup.bat. Do you see maybe anything wrong in it?
I'll keep checking for the issue. Thanks
Also I tried to add -certificate switch in open command, but always got an error msg like Unknown switch 'certificate'.
Did you try using an absolute path to the log file? /log=C:\backup\AICBackup.log
Also redirect even WinSCP output to your batch file log:
"c:\backup\WinSCP\winscp.com" /command  ... >>%logfile% 2>&1
