Delete files from SFTP older than 4 days
capjlp
Kentucky, USA
Hi I am trying to script a file that task scheduler can run every day that deletes files older than 4 days old.
So that files will stay on the sftp for 4 days then fall off basically.
Can you do this with a script that can be ran through a batch file?
Thank you
Round
UK
Sorry to drag up an old topic but I tried
rm *<30D
expecting to be only left with file less than a month old(ish)
Whilst it deleted many old files I am not left with the range I was expecting.
I am left with files older than 30days.
Any ideas?
rm *<30D
Please attach a full session log file showing the problem (using the latest version of WinSCP). Name a specific file that your expected to be deleted, but was not.
