Error Code 4 - Just started today
We are using version 5.9.5 using the sFTP protocol on a Windows 2012 server. I am running a .bat file using the windows task scheduler. Yesterday we were able to move the files from the remote server to the target server with out any issues. Today, we started getting Error Code 4. I checked and the AD user has full control of the target folder. There are no files in the folder when running the .bat file. Disk quota's are not enabled for this drive.
Below is the information from the .bat file (minus the connection information)
@echo off
/log="E:\WinscpLog\WinSCP.log" /ini=nul ^
/command ^
"Connection informaiton here:^
"cd /Files" ^
"mv *.pftap E:\Incoming\" ^
"mv *.scap E:\Incoming\" ^
"mv *.scgl E:\Incoming\" ^
"mv *.pftgl E:\Incoming\" ^
"exit"
if %WINSCP_RESULT% equ 0 (
echo Success
) else (
echo Error
exit /b %WINSCP_RESULT%
Here is the log message:
> 2017-05-16 10:43:26.647 Script: mv *.scgl E:\Incoming\
. 2017-05-16 10:43:26.647 Listing directory "/Files".
> 2017-05-16 10:43:26.647 Type: SSH_FXP_OPENDIR, Size: 19, Number: 2827
< 2017-05-16 10:43:26.676 Type: SSH_FXP_STATUS, Size: 47, Number: 2316
. 2017-05-16 10:43:26.676 Discarding reserved response
< 2017-05-16 10:43:26.706 Type: SSH_FXP_STATUS, Size: 17, Number: 2564
. 2017-05-16 10:43:26.706 Discarding reserved response
< 2017-05-16 10:43:26.706 Type: SSH_FXP_HANDLE, Size: 11, Number: 2827
> 2017-05-16 10:43:26.706 Type: SSH_FXP_READDIR, Size: 11, Number: 3084
< 2017-05-16 10:43:26.736 Type: SSH_FXP_NAME, Size: 545, Number: 3084
> 2017-05-16 10:43:26.736 Type: SSH_FXP_READDIR, Size: 11, Number: 3340
> 2017-05-16 10:43:26.736 Type: SSH_FXP_CLOSE, Size: 11, Number: 3588
. 2017-05-16 10:43:26.737 .;D;0;2017-05-16T14:43:26.736Z;3;"" [0];"" [0];rwxrwx---;0
. 2017-05-16 10:43:26.737 ..;D;0;2017-05-16T14:43:26.736Z;3;"" [0];"" [0];rwxrwx---;0
. 2017-05-16 10:43:26.737 Archive;D;0;2017-05-15T21:33:07.000Z;3;"" [0];"" [0];rwxrwx---;0
. 2017-05-16 10:43:26.737 brcm_fw_nic_17.0.4.5a_linux_32-64.bin;-;4866048;2017-05-10T19:21:09.000Z;3;"" [0];"" [0];rw-rw----;0
. 2017-05-16 10:43:26.737 ECMC_KS_20170516_1584955.scgl;-;23134;2017-05-16T06:00:18.000Z;3;"" [0];"" [0];rw-rw----;0
. 2017-05-16 10:43:26.737 ECMC_KS_20170516_1584965.pftgl;-;4176;2017-05-16T07:00:14.000Z;3;"" [0];"" [0];rw-rw----;0
. 2017-05-16 10:43:26.737 TB;D;0;2017-05-16T14:16:28.000Z;3;"" [0];"" [0];rwxrwx---;0
. 2017-05-16 10:43:26.737 Moving file "ECMC_KS_20170516_1584955.scgl" to "E:Incoming".
> 2017-05-16 10:43:26.737 Type: SSH_FXP_RENAME, Size: 84, Number: 3858
< 2017-05-16 10:43:26.766 Type: SSH_FXP_STATUS, Size: 47, Number: 3340
. 2017-05-16 10:43:26.766 Discarding reserved response
< 2017-05-16 10:43:26.796 Type: SSH_FXP_STATUS, Size: 17, Number: 3588
. 2017-05-16 10:43:26.796 Discarding reserved response
< 2017-05-16 10:43:26.796 Type: SSH_FXP_STATUS, Size: 50, Number: 3858
< 2017-05-16 10:43:26.796 Status code: 4, Message: 3858, Server: The requested operation failed., Language: en
. 2017-05-16 10:43:26.796 Asking user:
. 2017-05-16 10:43:26.796 Error moving file 'ECMC_KS_20170516_1584955.scgl' to 'E:Incoming'. ("General failure (server should provide error description).
. 2017-05-16 10:43:26.796 Error code: 4
. 2017-05-16 10:43:26.796 Error message from server (en): The requested operation failed.
. 2017-05-16 10:43:26.796 Common reasons for the Error code 4 are:
. 2017-05-16 10:43:26.796 - Renaming a file to a name of already existing file.
. 2017-05-16 10:43:26.796 - Creating a directory that already exists.
. 2017-05-16 10:43:26.796 - Moving a remote file to a different filesystem (HDD).
. 2017-05-16 10:43:26.796 - Uploading a file to a full filesystem (HDD).
. 2017-05-16 10:43:26.796 - Exceeding a user disk quota.")
< 2017-05-16 10:43:26.797 Script: Error moving file 'ECMC_KS_20170516_1584955.scgl' to 'E:Incoming'.
< 2017-05-16 10:43:26.797 Script: General failure (server should provide error description).
< 2017-05-16 10:43:26.797 Error code: 4
< 2017-05-16 10:43:26.797 Error message from server (en): The requested operation failed.
< 2017-05-16 10:43:26.797 Common reasons for the Error code 4 are:
< 2017-05-16 10:43:26.797 - Renaming a file to a name of already existing file.
< 2017-05-16 10:43:26.797 - Creating a directory that already exists.
< 2017-05-16 10:43:26.797 - Moving a remote file to a different filesystem (HDD).
< 2017-05-16 10:43:26.797 - Uploading a file to a full filesystem (HDD).
< 2017-05-16 10:43:26.797 - Exceeding a user disk quota.
. 2017-05-16 10:43:26.797 Script: Failed
. 2017-05-16 10:43:26.797 Script: Exit code: 1
. 2017-05-16 10:43:26.797 Closing connection.
. 2017-05-16 10:43:26.797 Sending special code: 12
. 2017-05-16 10:43:26.797 Sent EOF message
One thing I noticed is the "\" is missing from the to"E:Incoming".
I tried different target folders, but I am still getting the Error Code 4 error.
Again this worked yesterday, but started failing today. No patches/updates were applied to this server last night.
I am also not sure where to find a description of the error on the server as mentioned in the error message. I checked the even viewer and did not see any errors.
Thoughts?
Thank you.
@echo off
/command ^
"cd /Files" ^
"exit"
echo Success
) else (
echo Error
Thoughts?
Thank you.
