Local panel is no longer displaying files
davefrag
Stamford, CT
I'm not sure what I may have changed but, a listing of local files in the local panel is no longer being displayed. I can show the local directory tree which displays my directory structure on the local machine although the panel below it which would normally display the local files within the directory I've selected is no longer being displayed. The panel is displaying the total number of files and size within the directory I've selected although won't list the files.
BTW, I'm running WinSCP version 5.9.5 on a MS Windows 7 Pro system
Re: local panel is no longer displaying files
Re: WinSCP is not showing the local directory files
@Arunkumar: Please tell us more. Is this about a specific local directory or drive only? Or are you not able to see any folders/drives in the local panel? What did you try? Please post a screenshot.
