Automate --> copy new file SFTP to local machine and copy file from local machine to different SFTP
skumarlingam
NC
Hi experts please guide me how do i need to put below steps in one batch script
Here is the scenario what I am trying to make my code to work.
1. Get a new file(.xml) from SFTP to local system (new file will generate every 15 minutes)
2. While copying a new file(.xml) for every 15 minutes from SFTP to local machine the file name and extension should change to (SDF123.UVW.RFTI.YYYYMMDD.HH.01) and extension(bkp)
example:
UVW_TNI_09_CHAR_E_MM_DD_YYYY.xml (Source filename on sftp) --> SDF123.UVW.RFTI.YYYYMMDD.HHMM.01.bkp (renamed file name in local machine)
# Connect to SFTP server using password
open sftp://xyz:P@ssw0rd;fingerprint=ssa-xyz-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00@ftp.fg.com/usefor/fordownloadfiles/
# Download file
get UVW_TNI_09_CHAR_E_MM_DD_YYYY.XML D:\Shares\SDF123.UVW.RFTI.YYYYMMDD.HHMM.01.bkp
# Exit WinSCP
3.From Destination folder(local machine) the renamed file(SDF123.UVW.RFTI.YYYYMMDD.HHMM.01.bkp) have to move to sub-folder in same local machine.
set mytime=.0
if /I %time:~0,2% gtr 09 set mytime=%date:~10%_%date:~4,2%%date:~7,2%_%time:~0,2%%time:~3,2%
if /I %time:~0,2% lss 10 set mytime=%date:~10%_%date:~4,2%%date:~7,2%_0%time:~1,1%%time:~3,2%
COPY D:\Shares\SDF123.UVW.RFTI.YYYYMMDD.HHMM.01.bkp    D:\Shares\SIDS\SDF123.UVW.RFTI.%mytime%.bkp
(Note: I was trying to accomplish format YYYYMMDD.HHMM using set mytime code, somehow I am getting different format)
4.From Destination folder(local machine) the renamed file (SDF123.UVW.RFTI.YYYYMMDD.HHMM.01.bkp) have to move to different SFTP site.
# Connect to SFTP server using a password
open sftp://FRANK:P@ssw0rd;fingerprint=FRA-UVW-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00@ftp.gg.com/useme/foruploadfiles/
# Upload file
put D:\Shares\SDF123.UVW.RFTI.YYYYMMDD.HH.01.bkp /useme/foruploadfiles/ -nopreservetime
currently I am calling four different batch scripts in one separate batch script
CALL D:\Shares\Hold\BatScr\GETfileandrename.bat  (Covers 1 and 2 task)
timeout /t 30
CALL D:\Shares\Hold\BatScr\Copyfile.bat  (covers task 3)
timeout /t 30
CALL D:\Shares\Hold\BatScr\PUTfile.bat
(covers task 4)
YYYYMMDD.HHMM I am changing now manually now since script failing, somewhere my code is wrong in Task3.
Please guide me.
Thank you in advance.
Re: Automate --> copy new file SFTP to local machine and copy file from local machine to different SFTP
Use %TIMESTAMP% syntax
https://winscp.net/eng/docs/scripting#timestamp
get UVW_TNI_09_CHAR_E_MM_DD_YYYY.XML D:\Shares\SDF123.UVW.RFTI.%TIMESTAMP#yyyymmdd.hhnn%.01.bkp
You can use it even in batch file to generate the timestamp for your batch file commands:
https://winscp.net/eng/docs/script_formatting_timestamp_batch_file
