synchronize existing files only in scripting
henry3
Is there an option when using the synchronize local command in a script to only synchronize existing files or directories? I am excluding the directories I didn't need using -filemask now.
henry3
Solution to synchronize existing files only in scripting
I think this might work:
/rawconfig SynchronizeOptions=4
henry3
Re: Solution to synchronize existing files only in scripting
/rawconfig Interface\SynchronizeParams=4
Thanks Martin, I was looking at the .ini file parameter, and thought they were the same. In a .ini file could I just have the one entry ?
[m:318029ce7a][Configuration\Interface]
SynchronizeOptions=4[/m:318029ce7a]
Henry
Yes. But why? Use the command-line /rawconfig parameter.
